Hello I am French and I have a very poor command of the language I am bored with my silverado of 2016 crew cabin LTZ here is my rear bed leans almost 2 inches I am attaching pictures to you.  must we realign the suspension blades ??  should we change them ??  what is the problem?  the chassis leans on the left side front and rear when I but the weight at the right rear the front becomes normal I noticed a significant gap on the last right suspension blade I will tell you but some photos can you give me a solution  thank you to all of you
I think you may need new leaf  springs. Check the middle one on the saggy side Replace both sides.
I had a 2011 that had a broken leaf. Or as you call them blades.
Here's a link to some new ones....
https://www.truckspring.com/products/truck-springs/replacement-leaf-spring-22-1221.aspx?gclid=CjwKCAjwtpGGBhBJEiwAyRZX2sMaAFaeiISl_q4xeSr1W50QzeQx-COyP-I69nEYLfKnJ_5ieas2gxoC9PgQAvD_BwE
  • Haha 1
Try disconnecting the rear shock absorbers. I had a Suburban years ago that did this, it was a bad shock absorber.
I believe that during the trip from Canada to France when they were strapped, we had to strap it very hard on one side which crushed the rear left suspension blade
Yeah, first lift the truck, place the frame on jack stands, let the differential drop down, try loosing all 4 leaf spring bolts. Then lift up the diff. just enough to remove the shocks from the diff., then slowly let the diff. down (the leafs should keep it from going to far), then tighten all 4 leaf spring bolts TIGHT (100 to 125 ft/lbs) then with the shocks still disconnected, lift it, remove stands, let the truck down to the ground, if it is not even, then bad leaf springs, you will also know if the shocks still have gas in them if compressed and extend again.
i need lift blades, lol
it could have be caused by strapping it down like you said, leaf springs would be a starting point
Edited by pokismoki
indeed for me the cause comes from its I am afraid that I have to change the blades or I am told about it what do you think?
Won't help a broken part, but nice addition after you change the leaf pack if you plan on towing.
Ride may be a little stiffer than stock though.
yes I also think of that on the other hand we are talking about pieces breaking my blade to be deformed if the truck has remained strapped for 15 days in the container
without putting down the blades we can't see if there is a break in one place I think that to know if it's breaking we have to disassemble at first sight just by looking below we can't see anything
How does the front of the truck sit, wonder if it was damaged also.
Looks like it is sitting somewhat level on the lean side in the picture.
yes the left side sags and the front a little too on the other hand as soon as we put a counterweight at the right rear to balance the front of the truck is in line I think it was badly strapped on everything  the left side I will already repair the blade problem to see the correction on this model we can not cheat by adjusting the torsion bar there is none
well apparently I speak your language so badly that it was pointed out to me that instead of answering I report the messages again sorry to all of these errors I am French my father warned me when I was children (learn English well his  will serve you one day) lol I should have listened to it
You've done just fine. If indeed your truck was strapped down unevenly for that length of time it is quite conceivable that your leaf pack (blades) has lost tensile strength or retained memory of the compressed position. As dieselfan suggested replace the springs on both sides.
    Artemis
    Artemis
  • Who's Online   4 Members, 0 Anonymous, 1,234 Guests (See full list)
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
