Hello I am French and I have a very poor command of the language I am bored with my silverado of 2016 crew cabin LTZ here is my rear bed leans almost 2 inches I am attaching pictures to you.  must we realign the suspension blades ??  should we change them ??  what is the problem?  the chassis leans on the left side front and rear when I but the weight at the right rear the front becomes normal I noticed a significant gap on the last right suspension blade I will tell you but some photos can you give me a solution  thank you to all of you
I think you may need new leaf  springs. Check the middle one on the saggy side Replace both sides.
I had a 2011 that had a broken leaf. Or as you call them blades.
Here's a link to some new ones....
https://www.truckspring.com/products/truck-springs/replacement-leaf-spring-22-1221.aspx?gclid=CjwKCAjwtpGGBhBJEiwAyRZX2sMaAFaeiISl_q4xeSr1W50QzeQx-COyP-I69nEYLfKnJ_5ieas2gxoC9PgQAvD_BwE
  • Haha 1
Try disconnecting the rear shock absorbers. I had a Suburban years ago that did this, it was a bad shock absorber.
I believe that during the trip from Canada to France when they were strapped, we had to strap it very hard on one side which crushed the rear left suspension blade
Yeah, first lift the truck, place the frame on jack stands, let the differential drop down, try loosing all 4 leaf spring bolts. Then lift up the diff. just enough to remove the shocks from the diff., then slowly let the diff. down (the leafs should keep it from going to far), then tighten all 4 leaf spring bolts TIGHT (100 to 125 ft/lbs) then with the shocks still disconnected, lift it, remove stands, let the truck down to the ground, if it is not even, then bad leaf springs, you will also know if the shocks still have gas in them if compressed and extend again.
i need lift blades, lol
it could have be caused by strapping it down like you said, leaf springs would be a starting point
Edited by pokismoki
indeed for me the cause comes from its I am afraid that I have to change the blades or I am told about it what do you think?
Won't help a broken part, but nice addition after you change the leaf pack if you plan on towing.
Ride may be a little stiffer than stock though.
yes I also think of that on the other hand we are talking about pieces breaking my blade to be deformed if the truck has remained strapped for 15 days in the container
without putting down the blades we can't see if there is a break in one place I think that to know if it's breaking we have to disassemble at first sight just by looking below we can't see anything
How does the front of the truck sit, wonder if it was damaged also.
Looks like it is sitting somewhat level on the lean side in the picture.
yes the left side sags and the front a little too on the other hand as soon as we put a counterweight at the right rear to balance the front of the truck is in line I think it was badly strapped on everything  the left side I will already repair the blade problem to see the correction on this model we can not cheat by adjusting the torsion bar there is none
well apparently I speak your language so badly that it was pointed out to me that instead of answering I report the messages again sorry to all of these errors I am French my father warned me when I was children (learn English well his  will serve you one day) lol I should have listened to it
You've done just fine. If indeed your truck was strapped down unevenly for that length of time it is quite conceivable that your leaf pack (blades) has lost tensile strength or retained memory of the compressed position. As dieselfan suggested replace the springs on both sides.
    • Over the last week I installed GM coils, Taylor wires and Red Line SI-1 in the fuel which cleared up a slightly rough idle. Coils made the biggest difference even just A/B testing one bank at a time. I know everyone says the OEM ones last forever but at 212k on these units they were tired. Fade to failure, like shock absorbers in my experience. Also slightly richened the target idle AFR in the tune for good measure. I have zero tolerance for anything less than buttery smooth, and since emissions are not a concern I can get there any way I please.
    • ^^ Yep, that's all it was. The fuel line had rubbed through on one of the spider legs and was severely leaking. Even the lines/nut and bolt kit are harder to find and I think I paid $84 (Standard HK-11) for the kit. Ripoff. But when you're the only brand still making it...   There are a few things left before the truck is Atlas® Certified (and I've thoroughly spent too much on it considering what it's worth). My RockAuto shopping cart total is about $250 and growing:   -Radiator (there's a pinhole leak, driver's upper corner where a cooling line bolts in, the threaded insert weld cracked) -Water pump (mine squeaks, I assume it's shot) -Lower radiator hose (it's original, if replacing cooling parts, this shall be touched too) -Starter (It's not always engaging the flywheel, get the whirrrrrr sometimes when I turn the key but no crank) -Door hinge replacement pins (already purchased, need to install)   Suspect/borderline parts NOT included in shopping cart (only if I want to opt for bonus points): -Motor mounts. Someone twerked the radiator fan shroud, so I can't tell if the motor mounts are bad/squished or if it's truly just a deformed fan shroud. I reassembled the shroud correctly but the plastic is still re-forming/relaxing where it was all mangled and bent, and the fan still chafes it occasionally, but it's 99% better. -Left rear door speaker is blown -Rear wiper motor is shot (horrible grinding noise) -One of the wheels is missing the bowtie center cap. This drives me insane to look at, I'll just need to find a replacement.   I've already replaced: -Driver's door mirror -Idler pulley -Tensioner pulley -EGR -MAP sensor -Hood prop retainer -Intake plenum fuel lines -Intake gaskets -Thermostat (and flushed cooling system) -Radiator cap -Radiator overflow reservoir cap   And it needs tires, and could use a set of front brake pads, and the brake system flushed. And it could use a transmission service, and if I'm doing that, why not differentials, and transfer case, and oh hell, why not flush the power steering.   Is there anything I won't touch? Or...do I just get it to a point where I can send it down the road?
    • Was checking out a 39 Buick at a charity auction and found the statement on the cover of the owners manual interesting. What it can do for you, and what YOU can do for IT? Framing your ownership as a two way relationship! Seems this type of thinking is all but gone with the non-enthusiasts, and something like that would never be printed on the cover of a manual. It would likely offend people. Hey, I just spent two years salary on an SUV and it has the nerve to request anything back from me???? 😂
    • thanks, I'll look for that now.
    • Make sure your phone software is up to date.  Some people have had issues lately with bluetooth on GM radios and their phone had a security update or something that fixed it.
