For the 1500 the 2016 and newer have only assemblies. no bulbs. the 2014/15 fog lights were halogens, but the 16 and newer trucks had built in LED bulbs inside the assembly and cannot be replaced as easy as just a bulb. Really the only way to do anything about the fog light brightness would be to install something aftermarket or getting into a big can of worms with ripping open the housing(assembly) and taking the soldered in LED's and replacing them with a stronger one, by, of course resoldering them in.
Even with all that effort you still might not be doing anything substantial enough to get the result you are envisioning in your head. I would think the best option would be to get some LED pods and bolt them to the inner grille and wire em up to your fog lights or a full on light bar inside the grille.
Hope this helps.
Not a problem! Theres a few posts/threads on here with the pods/light bars. Look up a guy called TXgreek. He did a 30 or 32 inch curved bar inside the grille. Looks really well done. Others have done A Pillar pods with ridgid or baja designs with brakets. If your into that route, SDHQ has brackets where they fit in nicely. Check out their instagram. Believe they have a silverado/Sierra section where youd find em. Cheera man good luck! Dont forget to post in the what did you do today section when youve got something in. Not enough people doing those mods eivht now.
