I just switched out my rims and tires to aftermarket ones. I have reset the TPSM with the relearn tool. It resets but after a few minutes of driving the lights goes back on to reset again. Can anyone help?? Thanks in advance!
Did you start at the driver's front wheel and work around to passenger side and finish with the driver rear? You have to wait for the truck to Beep once at each tire, when done the truck should beep three times completing the process.
Yes I did. But I only got 2 beeps at the end. Should I keep trying it until I get 3 beeps at the end?
Sorry yeah it's two beeps after the beep on the right rear. Do all the tire pressures show in the DIC when you are driving after your done and then just go blank?
I had that issue after new rims were installed. I even bought an Autel TPMS tool to trouble shoot.
My issue would up being a low battery in the rear left sensor and the new 35" BFGs were impeding the signal from the sensor with the low battery.
Dealer replaced with a new sensor and all was fixed.
Yes they show then all but 1 driver front stays .
That means you have to replace those sensors, except the driver front.
8 hours ago, benny12 said:
How long should sensors/batteries last?
A few years is common, however, at times, they can last much longer.
That was a very nice PC answer😬, my guess would be until they fail..... much like your TV remote.
  • Haha 1
Which model did you buy?
The MaxiTPMS TS508
Edited by MikeBMW
But all the sensors are brand new. The TPSM is different then the one in posted.
If they are not pairing to the system, you'll need a proper scan tool to set them off and get them paired.
If they don;t pair up, even though they are new, they may be the wrong frequency.
Most K2s are 315 MHz.
3 hours ago, MikeBMW said:
The MaxiTPMS TS508
Very nice, professional grade, seems about right for me🤔😬
How do you like it? Think it has the range to help Cindy in LA?
  • Haha 1
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
