17 minutes ago, M1ck3y said:
Your cooling system is different. The 5.3 with the max tow gets the 8spd with 3.42 and the same cooling system the 6.2 has. Suspension is most likely different, shocks maybe leafs too.
I don't actually know your cooling system is different but that seems to be the consensus on here. I could do some searching on Google and post a link to the information. But so can you.
*edit*
Wow the 5.3 got 3.73's with the 8spd? That must be a fun truck.
You'll also have a smaller axle then the max tow (9.76)
Thanks, but the row I'm comparing to in the table isn't the Max Trailering Option.  Both options I'm comparing are in the EcoTech3 5.3L V8 section, not in the row for the EcoTech3 5.3L V8 Max Trailering option.  Or are you saying the trucks that fall into the green boxes I placed actually have a Max Tow package that isn't referenced there?
Edited by malibu43
Then the only difference is the gears.
*edit*
No  there's something wrong with that spec sheet.
Edited by M1ck3y
Just now, malibu43 said:
Thanks for clarifying.
Sorry no, there's something wrong with that spec sheet. It might have been made when gm was transitioning the 5.3 to the 8spd.
Don't trust those specs
Interesting. This is from my owners manual.  Lists the same options as the spec sheet, but makes no indication of which trucks have Max Trailering package.
Your owners manual is correct. But I'm fairly certain the max tow in the 5.3 only had 3.42 gears with the 8spd. And I'm struggling to understand how a 5.3 with 3.42 gears (Not max tow) is rated for the same weight as the 6.2.
Looks like the 5.3 should use the exact same cooling system as the 6.2. Or even if it doesn't, it's irrelevant because it's rated for 9000+ pounds.
So yeah, if your keeping the truck you'll just need gears. I would go with 3.73's if your going to all the trouble and money to do it.
I'd look into this more before going ahead with it though. Try and find build sheets for vehicles online and compare the differences (codes) between yours and ones with the 3.42 (Not max tow)
*edit*
Do you have the 6spd or 8spd? If you have the 8spd, you probably just need gears. If you have the 6speed your better off putting the money into a new truck.
Edited by M1ck3y
I have the 6 speed transmission with (from my build sheet):
G80 - AUTO LOCKING REAR DIFFERENTIAL GU6 - REAR AXLE 3.42 RATIO Z82 - TRAILERING EQUIPMENT PKG INCL: AUTO LOCKING REAR DIFFERENTIAL
and it performs quite well when towing.
To be fair, I haven't attempted a trailer as large as the OP has in mind.
Edited by MikeBMW
What's yours rated for with the 6spd?
Or are they all 6spd! I'm so confused now!! Gm should have stated the transmission beside each and every gear. What a mess.
Edited by M1ck3y
C5W - GVW RATING - 7,000 LBS
Hey everyone.  Thanks for all the info and help.  I was leaning heavily toward re-gearing then talked so some other trailer owners and did some research on how re-gearing will (or won't) affect the legal tow rating for the vehicle, and have decided it's better to upgrade to a new truck.  I really liked my truck and was looking forward to having it paid off soon, but I think this will be a better choice.
Inventory is pretty low right now, but we found a very low mileage used 2020 1500 LT with the 5.3L V8 and 8 speed transmission that we are going to look at later.  Had them send a picture of the door stamp and confirmed it has a Max Payload of 2071 lbs and max tow rating of 9600 lbs.  Almost everything else about the truck is equivalent to or better than what I had before.  I'm getting another 5 years of drivetrain warranty out of it, which is a plus.
It does need a hitch receiver (which is easy) and a brake controller (which I was going to have to add to my old truck anyway).  I may be back here shortly to ask for recommendations for those.
Thanks again for all the help.
Hmmm, the truck did not come with the factory tow package?
Personally, I might keep looking.
With inventory being as tight as it is, finding a 4WD truck with a V8, low mileage, with tow package (hitch and brake controller), with the tow capability I want, and at a price we can afford does not seem possible.  Out of all those things I listed, installing a hitch receiver and a brake controller are the easiest things to fix.  Unless I'm missing something...?
Edited by malibu43
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
