So new here and have a question.  I have a 2021 Silverado with the 6.2.  It runs great but at idle at stop lights etc it has a rough idle almost like a misfire.  I have the afm turned off and it is not equipped with the auto start stop.  I have taken it in to the dealer and the dealer says can not duplicate but it’s very obvious.  I only run 93 octane fuel.  Truck has 4000 miles.  Is this a sign of a lifter failure coming in the future ?  Do these trucks  just idle like this ?  Any help ?
Edited by Rcfire
Mine idles like that, I am just getting the high pressure fuel pump replaced under warranty and am hoping this resolves the issue, but I doubt it.
Keep me posted.  How did you get them to at least do that.  When I took mine in they act like they can’t feel it
Edited by Rcfire
The 6.2 has DFM, not AFM. How do you have it disabled? I'm guessing it's a post May build since you say it doesn't have auto stop/start.
Puddle of petrol pics on garage floor...lol
Of course they could not replicate leak on rack so I had to mention wife and son having headaches from the gas smell and that theybetter find something to fix.
Praying this was the culprit, post is below yours.
It is normal for the 5.3 and the 6.2.  They all have the rough idle you feel at stops.
2021 Sierra Denali 6.2L and it idles so smooth you can't tell its running.  10,000 trouble free miles since 12/07/20....
I been adding a bottle of this every tank full for the better of the 10,000 miles.  My nephew took one of mine and added to his wife's Cadillac SRX (75,000 miles) and it starting running smoother overnight to the point he bought a couple cases and adds it to every tank in the SRX and his Ecoboost Edge.
Mine is at idle when  in gear, feels like a distinct miss been that way since new.
13k on it now.
Yes I am sorry
Yes DFM I am sorry. I have it disabled with the pulsar
Yes I am sorry DFM.  I have it turned off with the pulsar
Edited by Rcfire
1 hour ago, Black02Silverado said:
Mine is a smooth idle.
Not starting anything but do you run 93 octane?
Yes I only run 93
Thank you I will try that
13k on it now.
That is exactly how mine is.  Have you ever had it in the shop for them to look at that ?  I just hate dealing with the dealerships but dang it’s drives me nuts when it does that.  I feel like a brand new truck should idle smooth
I run it as well in my Silverado and wifes Suburban.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
