I have a 2020 GMC Sierra xlt. Whenever I park my boat trailer and turn off truck the trailer LED tail lights flash every 10 seconds. Any ideas on what is causing this?
This is normal, it is stated in the owners manual on page 312.
"When a trailer is connected and the ignition is off, the Trailering App System will periodically pulse
the lighting circuits of the trailer to verify it is still connected. The trailer lights may periodically flash as a result of this trailer connection detection. These flashes may be more visible in dark ambient light environments. The flashing or flickering lights are a normal condition and the Trailering App System has built-in protections to prevent the battery from draining. When Theft Alert is also enabled
the frequency and pattern of this flashing will change."
Edited by JJ461
Yea mine does it too, it is the truck making sure the trailer is still connected.
Completely normal as stated above. First time I saw it happening I thought WTF??
10 hours ago, Chris Callanan said:
I've seen reports of folks with dead batteries in the morning though - so I unplug the trailer overnight just in case :)
I don't have any current facts to back up my position at the moment but I'd be shocked if the trailer monitoring system draws that much power to make a good battery discharge that much.
One thing to remember, there is a trailer alarm setting that will set off the alarm if someone disconnects your trailer, presumably in an attempt to steal it.
Edited by SVG
This is a feature I found out that the truck had at about 10:00 one night when I decided to unplug the trailer after the truck was locked... BTW the key fob was in the house, wasn't popular with the neighbors that night.
I, too, have this situation with my 2019 Chevrolet Silverado. When my truck is turned off, the trailer lights on my horse trailer continue to flicker repeatedly every 10-15 seconds forever. I’ve resorted to unplugging the trailer to avoid any draw on my battery.
NEW: I read not to long ago on this forum site that GM had come up with a fix. Some type of new computer module? My Chevy dealership had never heard of it so I had to furnish them the #specs from the Forum article I had read. It’s as yet, not a formal recall. Anyone know any more news on this issue?
Here is the page from my 2021 owners manual that talks about the trailer sensing. It says there is battery management software to protect the battery from discharging.
Maybe earlier year trucks don't have this feature? Not sure.
2021-gmc-sierra-1500-owners-manual copy.pdf
I have left mine plugged in for a week on vacation without cranking my truck at all and did not have a problem with it cranking.  It was nice to have them flash as extra security to let people know or possibly think it might be armed and not try and steal it.  We were riding atvs and from top of the mountain at night I could see my truck flash down where it was parked. Pretty neat.
They performed the tsb and plug fix on mine. Now lights only flicker on every 45 minutes or so
Quote
carlosh
Do you have the numbers for the TSB and plug fix.
My dealer is clueless or lazy or maybe both, but definitely useless at this point.
Thanks
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
