Read a lot of topics on flipping pill on 14+ trucks to lower trans temp.
has anyone attempted this (or is it even an option ) on the newer ten speeds?
what about changing out motor t stat?
Yes I was curious if this was an option on the newer 6.2 with 10 speed?
also curious if there is any long term feedback on let’s say a 170 t stat on the motor?
You want to know if the kit for the 6/8 & 10 speed is an option for the 10 speed? Don't even know what to say to that.
Had to go look at my records but I see I've been running the 170 F since 25K miles in a motor that now has 151K. If that is long term enough. Zero issues. No it isn't a 6.2. Yes it is an Ecotec3 of the same design and no it doesn't matter what the displacement is.
the question was really if there is a similar option
What temp did the trans run prior before the kit?
I did the flip when I notice on very hot days at highway speeds ATF running 215-235 F. I did try a second thermostat assuming it had failed but that was no different. So I either got two duds or.....
Depending on speed and wind direction. After the flip the same 95F day on a steady pull runs between 157-163 F. Day in and out it runs about 153 F summer. Those days are few in my area so a typical summer day is...well....lets look at my charts:
Note this is coupled with the lower water thermostats. Also note that the difference in water temperature is not as effective on the ATF temperature as the pill flip and the colder it gets the less effect it has.
Does that answer your question okay?
They use the same parts. So it's not 'similar', it's identical.
You bet.
Thanks for collecting, graphing and for posting!
The 10L90 behind my 3.0L dmax takes a bunch of miles to warm up, but once it does it always settles around 180F -- so not as hot as yours was running. Towing, high speed, rural 2-lane and ambient temp don't seem to have a big impact on that number.  I never run long periods of stop and go so can't speak to how it would perform doing that in high ambient.
27 minutes ago, redwngr said:
You bet.
Seeing the same with mine.
-Grover67
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
