I have a 2004 SLT 4x4 with bad brakes. I had the brake lines replaced 4 years ago when they rusted out and started leaking.
Brakes now go all the way to the floor and stop the truck although slowly. Just paid $700 for new front calipers, rotors, pads and lines. Bled with scan tool. This did not improve the brakes. Mechanic said the auxiliary P/B booster pump is bad. When plugged into the harness it runs continually with vacuum and pressure at the nipples. This part is unavailable. Part #
89058946. Do I now junk the truck due to an part that is not obtainable?
Has anyone else had experience in solving this problem? Is there a solution?
Thanks for the links. I just talked to GMC shop. They advised to bring the truck in. Their thinking it is not a problem with the booster pump as it runs and creates vacuum. They are thinking that I may still need  lines bled manually first at rear wheels then front then at the abs block. Also to check master cylinder. I guess I will try this before trading it in for a ugh Mopar.
booster will not cause your problem, most likely bad master cylinder. a bad booster would cause the pedal to be hard to depress enough to stop the truck but not affect pedal travel
Thanks. Getting that checked at GMC shop next week. I can hold the brake all the way down give it a little throttle and the truck will start moving with the brakes pushed! Looks as though I may have spent $$$ on new calipers, rotors, pads, and brake hoses that weren't needed. Live and maybe learn.
Yeah the calipers, pads and such aren't your problem; a master cylinder issue is my educated guess. GM publishes trouble shooting checklists for all systems....
Edited by dna9656
Thanks. So to the dealership next week to spend more money all on a truck that is to be traded in. just didn't like the idea of passing the truck off with a known safety issue even if the dealer will probably send it to auction.
can you pump the pedal and have it come up and stay there with your foot on it?if so theres still air in the system somewhere. if it still creeps to the floor its either the master cylinder or you have a leak somewhere
OK. So most likely the master cylinder. It will not stay pumped up and their are no discernible leaks. I now remember that not long after I got the truck I did have a brake fluid leak and all the brake lines were replaced. This was about 4 years ago. The mechanic said there was one item he was not able to replace because it was too rusted. The brake line kit parts were supplied by GMC at their cost. It was after this happened that all the trouble started. I questioned that tech about the weak spongy brakes after the repair and he said that is just the way they are with abs. Recently had a cam and dyno tune installed. The tune increased my idle speed slightly and now it seems really hesitant to stop and to hold at a stop.  I guess I could have the most recent repair shop that replaced the calipers, rotors, pads and hoses to do a master cylinder as he has wasted $800 of my $ maybe he will give me a break! That or just go on to the dealership?
lots of shops just looking to make the fast easy $doing half ass brake jobs, the mark up on brake parts here north of Boston is %100. they didnt take the time to properly diagnose your problem OR when they did the job they pushed crap back into the abs & master. the properway to compress calipers is 2 clamp off the brake hoses and open the bleeders as the calipers are the lowest parts in the system so all the debris ends up  in them. VERY few techs do this tho. its a shame you have to go to the dealer and cant find a competant independant.. the shop that did the brake job was foolish to release the truck like it is, you could easily have crashed and hurt yourself or someone else opening them up to a lawsuit. its 1 thing if your truck doesnt start but a whole different thing if it doesnt stop
This is the same shop that removed the aux. booster motor, said it was faulty and hooked the brakes back up with the vac line into the booster instead of through the aux booster motor. I had to ask for the aux motor back. When I plug in the motor it runs and pulls vacuum. Now I need to remount it along with bleeding or master cylinder.
Is this correct operation for this part??
  • 2 years later...
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
