On 5/23/2022 at 7:11 PM, Guy Horneker said:
Call GM. Filed a complaint. The dealership also inquired with GM. GM approved and sent dealership a check for the price increase.
Hey Guy, can you let me know the process you took for this?  I am currently in the same boat where my dealer is telling me I owe more because of the msrp increase.  I have not took possession of it yet, so hopefully can get it figured out before I do!
If you put a deposit down on a truck, the price is set. Tell your dealer they are lying and threaten to call GM corporate to complain and I’m sure they will change their tune quick. GM sent emails out to all customers with a reservation and specifically told them their price is set
Medic, I don’t think it’s the dealer. They are showing the new msrp for the truck from GM, and not the original msrp that was quoted.  I mentioned that to the salesman and he is going to verify as well, but I don’t want to wait/count on him.
To me that’s still effed up to change the price on a buyer when they already put a deposit down and a price listed on the build sheet…I wouldn’t normally worry about it, but it’s $4k higher!
The last sentence says to lock in your MSRP. Legally when you put a deposit down on a vehicle you enter a binding contract say I will put this money down to get this product. Any changes have to be agreed upon by both parties.
Edited by Medic4552
Your price is locked the day you ordered the vehicle from your dealer. Not the day you put the $100 deposit down from the GMC reservation website.
Your dealer should have given you a receipt the day you ordered it that shows the price and everything you ordered. Make sure the date on that receipt is before the price increase took place.
Ok, so I get everything y’all are saying, but since the dealer doesn’t know how to do that *cough *, how do I go through GM to get it changed?
This is great information on the pricing. While I would have paid the increase since I am already so far down this road, it is good to know I am locked in at my order price back in January. Not my fault GM is taking forever to ship my produced order.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
