It's rough getting old... I have had this truck for well over 5 years and saw something that didn't seem right today. I have the dual zone climate controls that have the auto setting. Today, I did the remote start to let the truck warm up and allow the heat to start working. When I shut it off yesterday, I had it set on Auto and HI for the most heat. So I'm pretty sure that whatever it was set at when last shutdown is what it does when remote starting. That, I'm fine with.
But after putting the key in to drive away, I happened to glance at the climate controls and noticed that in Auto, only the AC button light on,  which I know is normal, and the Defrost button light on. I was almost positive that I should see other button lights on and was sure that they were but now I'm second guessing myself. I did manually press some like the airflow to feet, the recirculating button, airflow to dash, etc... and each one lit up just fine and obviously the Auto option turned itself off. So all the button lights seem to work as they should, just don't light up in Auto.
Am I just getting old and forgetful and this is how it always worked or is it a problem that I might need to check out and fix?
WHen mine is in AUTO, only the air conditioner light is on otherwise.  Switching any other setting turns the AUTO function off.  The only thing I can change in AUTo is the temperature setting so far that I have noticed.  Good Luck!
This is with the key in the ignition? I'm not sure about about after a remote start, key out. But, without checking I'm pretty sure they all light up. Doesn't really make sense though, because your's light up when depressed so they're not burnt out 🤨
I may be wrong on this but when on AUTO, the computer will direct the air flow to the area it thinks is needed AUTOMATICALLY.
When you push/select a specific vent you want, you are overriding the AUTO function, which turns the AUTO off and tell the system where you want it. The AUTO function also sets the fan speed. If you change that speed manually with the fan knob, it will turn of the AUTO function as well. Hope this helps
Right, I think he talking about whether or not all the buttons light up with auto selected? I thought they do but no I'm not so sure🤔
Edited by M1ck3y
2 minutes ago, M1ck3y said:
Right, isn't he talking about whether or not all the buttons light up with auto selected?
Mikey?
Yes, this is specifically when using the Auto mode.
Ok, I'll be sure to check out tomorrow if someone doesn't beat me to it.
I can manually change climate control choices and the Auto goes off and all the lights come on like I figure they should as I make the choices.
Looks like I may have just not been paying attention before and now that I have a lot more spare time, I'm slowing down and noticing things I never thought much about before...
This is kind of what I'm thinking, I just assumed that depending on whether it was going to the floor or dash, or even both, there would be an indicator showing which is being used. I know it's easy enough to just reach out and check with my hand where the flow is, I have just gotten spoiled, I guess you can even say lazy, by just looking at indicators to tell me what's going on.
Lately I've gotten used to checking various things telling me information such as trans temp, tire pressure, fuel mileage, etc so that I'm paying more attention to the gauges and indicators that I pretty much ignored before. I'm starting to think that this is just one thing that I overlooked before and is probably functioning normally and like it always did...
In Auto, only 3 lights could be on, Auto, AC, and if you sync both sides. If other function lights are on, you are not in full Auto mode.
  • Like 4
Looks like my observational powers had been lacking and it's functioning as it is designed . Now I know, thanks!
I do believe that when remote started, in colder temperatures like it's been, the defrost for the mirrors and rear window will also come on and stay on when key gets turned to on even in Auto mode. I should have been more specific on which defrost I was speaking about above. This has always been the case as far as I'm aware and I had previously noticed this. However, I pulled the fuse for the rear window quite some time ago after seeing all the posts about rear windows shattering so only the mirrors get the defrost treatment. The front seats will also warm up with remote start but those lights don't come on and it disables after key on and has to be re-enabled manually
Rear defrost/mirrors has to set to come with remote start. Setting is in the radio with everything else.
  • Like 4
When you do remote start it does the heating and cooling depending on the outside temp. Doesn't matter what your last setting was. When i had a 2016 ford escape you could choose last setting or let the computer do the heating or cooling. On the gm truck you don't have that option.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
