what are you guys doing once you install gears and 35  tires to recalibrate the speedometer ?
my truck originally came with 3:23 gears , so i upgraded to 4:10  and 35 tires
speedo is way off  98mph on the dash  80mph on the phones GPS
dealer or programmer ? whats the best option ?  cheapest option
If you don't want a tune you can use something this which is what I originally used(check and make sure this fits your truck)
Hypertech 752501 Speedometer Calibrator https://www.amazon.com/dp/B006RQ44O4/ref=cm_sw_r_apan_glt_fabc_P47AM0A8PKWZVMX432MY
I've since switched to black bear tune and would highly recommend going that route.  Made my truck drive like a sports car.
Edited by m3n00b
Dealer can only program for factory sizes.
Programmer, tuner, calibrator, etc. are your options.
Off topic, but does that mean your speedometer shows 18MPH when you are stopped🤔😬
no , its off because the gear change , and bigger tires
its proportional.
The sensor is displaying 1.225x the actual speed because the tires rotate 1.225x less than OEM.
From middle school math 0 x 1.225 is still 0.
i use the truck to pull the boat and daily driver, so it only sees 87 octane fuel , to take full advantage of a tune you have to run 93 ,i just want to recalibrate the speedo the cheapest way possible  , we have a gov at 98mph in my case i cant pass 80mph on the highway , need to fix this ASAP
Not so, you can tune for 87 or whatever and still see performance gains, especially in the transmission.  A BlackBear tune is not the least expensive way possible but is your best bang for the buck!
Write me up for 98
Post my face, wanted dead or alive
Take my license, all that jive
I can't drive 98
Oh yeah
(I can't drive 98)
(I can't drive 98)
(I can't drive 98)
(I can't drive)
98
Uh
Yea had too.
  • Haha 2
problem is if you live in the great state of Kalifornia you can't get one delivered here and the new cars will tell the computer at time of smog check that a tuner had been installed and removed.... talking about Big Brother
16 hours ago, Supreme Pizza said:
There is always someone there to let you know EXACTLY how fast you were going....
I use Waze to tell me the posted speed and the curreent speed... but I'm going to order the Hypertech because has a Kalifornia approved sticker.. but i have to buy the one without a tuner...
    • I would like to know if I can increase my 2025 Silverado 2500 HD
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
