Hello, I have a 1999 sierra, when I put it in auto 4wd it acts like it is in 4hi. I do not have any cel, or service lights on. All the lights on the push button 4wd switch work. Any idea where I need to start looking as to why it is doing this. Thanks in advance and thanks for the add to the group.
If I'm understanding this correctly its because it is in 4Hi and thats why its acting that way.  IF the truck senses the road conditions need it to be then it will be in 4Hi.  If its in snow, mud, or senses any traction issue it will be in 4Hi.  If its a hard dry surface it should be in 2Hi.  If its a hard dry surface and it feels that way, something is wrong.
If I'm wrong on this someone feel free to correct me.
Edited by Jworks
Are you saying that in AUTO you are getting binding when turning in the front end like its in 4HI?
I was on dry hard surface and put it 4auto and front axle was binding like it was in 4hi. I had a 1999 Tahoe and used the 4 auto and never felt like that.
While in auto 4x4 there isnt power persay to the front axles but they are on demand or activated in case you are in a situation that say you are cruising highway speeds, come to a hill that might be a bit slippery, the auto 4x4 detects that you are losing grip, and automatically puts power to the front axle, where as if you didnt have this feature activated you would need to push the button (which you should do anyway) for 4 hi.  It is sort of like a clutch.  A slight moan is humming is completely normal, at least its been for all of my trucks when I have been in auto 4 or 4 hi.
If its a auto 4wd mode - Make sure you have the correct fluid in the tranfercase, sometimes you can do a fluid change and then 50 miles later change again, if condition still present you will need to adjust the cluct pack in the transfercase, with either new discs and plates and or selective plate.
Edited by rbdjr
Gotcha.  You could start simple, get 2 quarts of fresh GM AutoTrak II Fluid (the blue stuff) and drain out what's in the case.  I suppose there is a possibility that old or wrong fluid could be making the clutches send power to the front when it shouldn't.
The more likely scenarios would be that the encoder motor (transfer case actuator) isn't shifting the transfer case correctly and is only giving you 4HI.  There could be an issue with the transfer case control module, but you'd be seeing codes with that.
You are getting driving symptoms of being in 4HI, so it sounds like the front axle is actuating properly, so that leads me to think your issue is in the transfer case.
Edited by newdude
I will give that a try. I did have an error on the abs side, bad wheel speed sensor i changed that and cleared the codes and so far so good. I thought I read if there was an error on the abs it could case issues with the 4wd, was hoping that this was the case but it wasn't. I like the auto mode for winter driving. Thanks for your insight.
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
