How about changing the forum titles to include my new 2022 Denali Limited or make some new ones👋👋
Since Chevrolet's SuperCruise has late availability and the Denali Unlimited has that as standard, nobody is going to have one in a while.
Edited by Wiggums
I have a 2022 Denali Limited. There is no forums that includes this. They all stop at 2021. Apparently the world ended and GM stopped making vehicles in 2021.
I believe you are thinking of 'Denali Ultimate', rather than 'unlimited'.
Limited designation (or LTD) -- applies to all the '22's that built same styling/features as the '21's  (meaning the unrefreshed  trucks).
Supercruise will be standard on Denali Ultimate, and it will be available on High Country and on the regular Denali.
  • Thanks 2
All an admin has to do is change the number from 21 to 22 in the title, would be very simple.
But either way, your 22 is just like a 21.
  • Thanks 2
Many thanks for the clarification. Ultimate, Unlimited, got it... bah. Now the OP makes sense. LOL, thanks!
8 hours ago, Transient said:
Is somebody feeling a little left out?
I don’t exist 😂
It’s the same as a 2019, 2020, and 2021, no reason to make a new forum for a 2022 when it’s the same truck with a different dash.  I don’t see what the big deal is unless you just want to let everyone know your special because you got an “Ultimate”, in which case…
Edited by Gangly
  • Haha 3
Not a new forum just change 2021 to 2022 to be accurate. And it’s not an ultimate it’s a limited.
LOL
You would think the higher priority for the site would be to replace the pic of a camo'd prototype on the "2021 Tahoe, Suburban, Yukon, Yukon XL & Escalade" forum since that vehicle was released a long time ago.
  • Haha 1
I don’t get why this is an issue. It’ll get done whenever it does. Clearly the 22 Limited is the same as a 21. The admins will get to it when they do.
10 hours ago, Mad Max said:
I don’t exist 😂
They are probably waiting for you to change your truck info under your avatar..🙂
Still says:
  • Name:Doug
  • Gender:Male
  • Drives:2014 Silverado LTZ Z71 CC 6.5' Bed 5.3L 3.08 Build Date 17 Jan 2014
  • Haha 5
Still says:
  • Name:Doug
  • Gender:Male
Thanks for bringing that to my attention. All fixed except I got a find a build date somewhereThanks for bringing that to my attention. All fixed except I got a find a build date somewhere
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,030 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
