I have a 2021 Yukon xl and was wondering if anyone has tried swapping out the switches to a 2022 for the hard button for the camera. I know it’s a long shot, but any chance it’s doable?
asked a dealer and they had no idea.
Man, this forum doesn't get as much help as the truck side of things.
Anyways, update on my question.  IT IS PLUG AND PLAY for my 2021 Yukon XL Denali (build date May 2021).
Several people were saying it was not possible and just to trade up to a 2022 model, but I didn't want to lose any features I currently have. This was by far the best $70 I have spent on this vehicle.
There are 25 part numbers for the switch with camera, so you will need to figure out which is correct for your vehicle based on RPO's. Parts guy at the second dealership I went to (first was not interested in helping me) was willing to print out the list for me to figure out which it was as he could not find it based on a VIN I gave (I have attached the part numbers pages so hopefully others can find their's easier).
Mine was an ultimate:
UHX: Lane departure
JHD: Hill Descent
UD5: parking sensor
KL9: Auto start/stop
UV2: 360 camera.
Z88: GMC
Other RPO's listed:
NSS: no start / stop
X88: Chevy
You can find your RPO code on the driver's side door jamb and scan it with your phone camera to read it.
Once you get the part, it literally took less than 10 minutes.
  1. Popped off the 2 panels: Do the bottom left of the kick panel first, then do the side piece.
  2. remove 7 mm screw that holds the trim piece with the switch.
  3. pull straight out on the trim piece with the switch (4 retainer clips, see picture).
  4. remove clip but first using small flat head to slide red locking piece out (to the right in the picture) and then flip green piece down and it will release the harness.
  5. Remove switch from trim piece with small flathead to release clip at each corner.
  6. Install new switch and then put everything back!
Very informative posts. I have a 2021 high country suburban with the same switch setup as you. Ordered part # 84786497, I will report back with another data point after install. I also plan on installing an auto stop eliminator at the same time.
FYI, for anyone with a non Denali Yukon or Tahoe/Suburban the switch panel disassembly/assembly is covered in a video on the auto stop eliminator web site.
Installed my switch panel today, everything works as advertised. It’s nice not having to navigate the touch screen to get the 360 cameras up. Thanks peterlawl84 for sharing the information to make the swap possible.
Thank you for all your help on this! We have an 2wd Duramax Yukon SLT that does not have Hill Descent Control. I ended up ordering the part number 84786496, and I also paired it with the auto stop eliminator and everything works great.
My 2021 Suburban controls do not have the hill descent button.
It looks like b0hr found the right part to substitute to get the camera function.
But, if I add the button assembly that peterlawl84 used, will I also get a working descent button?
Is that plug and play also?
b0hr, what is the auto stop eliminator and where do you get it?
I can guess what it does but what does it look like and how is it installed?
You will not gain descent control. thats a separate module.  This has been confirmed by others that tried to use the same button I did on their vehicle without it.
Another successful installation.
As noted by b0hr above I used part number 84786496 for my 2021 4WD Suburban LT.
I also installed the TRL Autostop Eliminator at the same time.
Everything works great!
OMG this has been driving me crazy ('21 Yukon Denali). Stumbled upon this thread and just ordered the upgraded part (84786497). Can't wait to have a hard cam button - thank you, all!
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
