I have a 2019 LTZ with 6.2 15,000 mi. Past the 3yr 36,000. It’s just sitting in storage for now waiting for me to relocate this spring. I have someone starting it every couple weeks and they have to jump it. My question is is there a better battery then the factory GM one? Or will the local auto parts store work. Thanks
Better is tough, the lead acid batteries are nearly the same.
There are 3 major manufactures of batteries in the United States, it basically makes no difference on who you bought a battery from. They are all made to very very similar specs and only the color of the case and the label is the biggest difference between them.
If you want to switch away from a lead acid battery I would suggest a AGM (absorbent glass mat) style battery.
The AGM's are geared towards very well equipped vehicles with lots of electronics because they will handle it better and should last longer overall than a lead acid battery. They do run about $50 more than a standard battery and right now they are pretty hard to find too.
The batteries in our trucks are the AGM battery not the typical lead plate battery they are alot better battery then the lead plate battery, but it takes them awhile to become fully charged so starting truck up for say 1/2hr does nothing to charge them you're really running the battery down even further by doing so. To get them up to full charge the truck would have to run for hours for a completely run-down battery. If you get a battery tender or charger MAKE sure its compatible for an AGM battery. A typical charger when on an AGM battery will burn up the battery do to it not shutting completely off when the battery reaches full charge. A typical lead plate battery should not be installed in vehicles that call for an AGM battery as the charging system in our trucks and vehicles that have that type of battery are very complex.
AGM's charge faster than lead acid batteries according to Interstate Battery.
https://www.interstatebatteries.com/blog/what-is-an-agm-battery-and-whats-the-big-deal
Also the 2019+ trucks came with both style batteries from the looks of it. You can buy either or. GM Parts Direct and same with Napa online list both options for these trucks.
Fun fact too, GM only lists one alternator for the V8 trucks too. So the charging system is the same for both batteries. They also already have a smart charge system that is PCM controlled, been that way for 15 years now. Not trying to discredit the above post but it's not as complicated as he made it sound.
 I’m going to try a new Odyssey AGM along with the tender. It’s also sending me a Onstar report sayin the antilock brakes and power train needs attention ASAP. Hopefully it’s do to the low voltage.
Just purchase a battery tender for an AGM battery and you will be fine.  No need to get paralysis through analysis.
A low battery will cause all sorts of error codes and messages to pup up.  Charge the battery or get a new one and put a battery tender on it and you will be fine.
    • Sir, economics doesn't have a moral compass. 😉 Just say'n.
    • One would think. BUT....This is what a Google search gives for the GM OLM system:    It doesn't measure oil condition save the highly indirect water temperature. It should measure oil temperature and as we've discussed they are not as closely related as one might assume. The algorithm is based on expected conditions at the end of a certain number of miles or revolutions. And sirs, this estimated value is not tilted in the engines favor. It favors the OEM's bottom line. There are no magical number of miles nor revolutions. No magical time limit. There is only what can be measured directly and only in the broadest of terms would the values used even come close to reality.    It samples nothing. It has no idea where the oil started or where it will finish given the limited values use to create the algorithm. It is just a reminder for the brain dead to do something at some time to keep the warranty in tact. Pure fiction.    Key Factors in Oil Life Calculation The OLM calculates the remaining oil life percentage based on the following factors: Factor Description Engine Revolutions Tracks the number of engine revolutions since the last reset, decreasing oil life with use. Mileage Since Last Reset Monitors the distance driven since the last oil change, capped at 7,500 miles for most models. Time Since Reset Decreases oil life over time, dropping to 0% after one year, regardless of mileage. Engine Temperature Adjusts oil life based on coolant temperature; exceeding 260°F sets oil life to 0%.
    • Towing power and I guess MPG matter that’s why I may end up going with a gear swap as soon as they’re available for this truck if I’m correct
    • If I may, I'd like to post my prediction of the trim levels for the 2027 GMC Sierra, based on what was released/introduced today about the Chevy Silverado.   Using the "Professional Grade" wording already in use by GMC, here are the eight (8) trims I believe the Sierra will offer (comparable Chevy trim in parenthesis): Sierra Pro (Work Truck/WT) Elevation (Custom) Elevation Premium -or- Ultimate (Silverado) AT4 (Custom Trail Boss) AT4 Premium -or- Ultimate (Trail Boss) AT4X (ZR2) Denali (High Country) Denali Ultimate (N/A) If GMC would rather simplify the trim levels, then I predict six (6) with package upgrades in parenthesis: Sierra Pro (with a Graphite package upgrade option) Elevation (with a Premium -or- Ultimate package upgrade) AT4 (with a Premium -or- Ultimate package upgrade) AT4X (with AEV and Ultimate packages upgrade) Denali Denali Ultimate  Let's see if I'm close.
    • I have to believe there are already a bunch of threads on this, but my searches didn't turn up much. While I like the ease of a plugin solution like the Carbyte, It appears it disables the AFM or DFM too, and is not configurable to only disable the auto stop/start. So, I'm looking at the Autostop Eliminator product. I like the idea of it better, but I'm concerned about the install and having to pull so many panels to get it installed. Mines a 2026 work truck, so from what I've read it's a less involved install, but having watched a couple install vid's, I'm still a little intimidated. Might need to buy some plastic trim tools to get it done without breaking or marring stuff. Any experience intalling in a WT greatly appreciated.
