Hey y’all! Small scale random mod question. Does anyone keep anything cool under the hood where their secondary battery would go? I was thinking of mounting a water canister, toolbox, first aide kit or something of that nature. Hate having space and not utilizing it!!
I have my clutter of wires, fuse blocks and relays for my lights there. Would like to dress it up to look cool and functional not just functional.
I installed a coolant filter
This is where I mounted my fuse/relay block for my aux lights.  The fuses, relays, and wiring fit in a 7" x 11" x 5" junction box with a removable lid.   Have 4x rocker switches in my overhead console that switch my ditch lights and reverse light pods.  (The other two are spares for now).
Not sure if it's "cool".....but certainly functional and easy to access.  I WAS gonna put a catch can there.....but will end up putting that in the rear of the engine bay.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
