Hello everyone.
I've got a 2022 GMC Denali 3500 with pretty much ever option available except for the plow package and rear heated seats.  Yes I ordered it in June of last year so all the options were still available at that time.  Any way.  I'm looking to mount the face plate of my ham radio and I'm not sure how to do it.  I was thinking I could put it in the center on top of the dash where that tray with the rubber mat is.  I'm just not sure if there is a way to securely mount it there.  I would have to build my own mount probably unless someone knows of a third party one.
If anyone else has some options let me know.  It's a bit to big to put by the A pillar.
Thanks.
I found one at A-Tach but they don't ship to Canada.  Found a supplier that does ship here and they want 53.00 US to ship it.  Very frustrating.
Cut a block of wood to fit squarely in the dash tray. Mount your radio head there.
Thanks gemarsh.  That might work.  And they ship to Canada.
12 hours ago, VE6CPU said:
Hello everyone.
Thanks.
What radio - Yaesu , icom , kenwood ???    I have a Yaesu 8800 mounted on the dash next to A pillar . No problem seeing .
Edited by slj2008
21 minutes ago, tbully said:
Hello!
I use a mount on the center console from ProClip!  It works great for my Icom 5100!
Any chance you might have a picture you could share?
I have the same radio, and have used ProClip in the past on a Jeep Rubicon.  Very nice quality.
Also would really like to know how you handled the antenna install?
BTW: Love that radio.  I caught a conversation over D-Star with a guy on the east coast talking with guy in S. Korea.  Would be nice if Kenwood, Yaesu and Icom could agree on a single standard in that regard.
Here you go!
That is awesome! will need to check into this option.
Thanks!
@VE6CPU sorry for horning in on your thread.  Got excited when tbullly mentioned using the proclip with the Icom, as I've had great experience with their products, but didn't realize they made one for our trucks.
No problem sheath.  The more that weigh in the better.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
