11 hours ago, lennybg said:
depends on his powertrain warranty... mine was 5/100,000. My lifters went out at 79K.
You are very fortunate. Most people don't have that kind of coverage.
Chevrolet would maybe consider it if a local dealer, diagnosis the failure along with you had brought it in prior to failure while still under warranty for issues relating to lack of power.... Well that is what I found out this week after Chevy Ducking me around for the past 4 months. I am out of Engine Warrantee but still in powertrain and I was told they wont do anything for me.
I had the Pulsar LT since new back in 2021, with Disabled AFM/DOD.... there is a service letter for Chevy 2020/2021 built engines for 8 months they build engines with lifters failing internally that where supposed to be changed prior to sale of vehicle.
If you do rebuild it and want to have DOD/AFM delete done, it will cost $1000 US for someone to Tune it VIA HP Tuners, plus you have to send your VCM to HP tuners at around $ 500 to get unlocked, also have to buy 6 Credits at $50-60 a credit to have your truck tuned on top of a tuner's cost.
I barley had a failure just started to Tick, needless to say I need CAM, Lifts, pushrods, Main bearings, Cam Bearings, gaskets, oil pump etc............ HONESTLY for the price of parts labour and TUNING, buy a crate engine its cheaper I personally wish I did after adding up the cost of everything, with down time and rental vehicles.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
