Picked up a new 5x10 utility trailer this weekend.  Drove it about 100 miles to pick up an ATV.  On the way, empty, it towed just fine, no issues.  Once I loaded the ATV (about 700lbs) and started to drive home, I experienced some pretty significant vibrations at highway speeds, around 60-65mph.  The vibration was variable and would get worse at times and then subside, but significant enough that I could see the front of the truck shake.  The trailer was level and I adjusted the load a bit during the ride back to see if it was due to the weight distribution to no avail.  Now I've towed other trailers with heavier loads with my truck and they were always smooth as glass, no issues.  I'm not thinking it's the truck.
When I got home, I raised the trailer to check the wheels and tires and found that both tires had at least 1/8 inch of run out (not round).  The rims where good.  When I spun the wheels you could visibly see the vertical wobble.  I thought it might be flat spots, but after 200 miles those should have resolved themselves.  My question is, would a 1/8 to 1/4 inch run out (both tires) cause this type of vibration?  The trailer dealer is checking with the manufacturer on next steps, but looking to see if anyone else has experience here.  Thanks
I think it would once the weight was put on the trailer, I'd take the trailer out empty again and see if you still experience the same vibration, I think that would prove it out.
Weight distribution to far to rear of trailer can make it wiggle, sometimes violently.  Worse at higher speeds.
I would replace the Chinese tires with Goodyear Endurance tires.
Quote
Definitely, the trailer tires are junk as most are on cheap trailers.   Neighbor said same thing about cheap trailer he got at Tractor Supply, shakes his truck when he hauls the lawn tractor around.
Edited by elcamino
That's likely my next move.  It came with the chinese Goodride tires.  I went out and checked this morning and found that both tires were overinflated by 10lbs (60lbs on a max PSI of 50).  Likely overinflated while it was stored on the dealer's lot and they didn't adjust them before I drove off with it.  I'm sure that extra 10lbs didn't help either.  Trailer dealer was "checking" with the warranty department and I'm waiting to hear back.  Trailer is a new Big Tex 30SA.
Edited by OliverDennis52
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
