Does anybody know where I can find a machine shop that does high quality work that has experience machining alloy wheels?
I have a pretty simple job I’m needing done by a machine shop and it needs to be done right.  I have a hub I can ship to them from a truck like mine so they’ll be able to see the exact amount of material to remove...
I want to put some GM wheels (Hub Bore Size 78.1 mm) on my midsize truck (Hub Bore Size 100.3 mm) so the bore needs to be made 22.2 mm larger (both wheels have same bolt pattern, so that part is good to go).
The machining only needs to be 1/2 inch deep so this should be a simple job.
So, if anybody knows of a machine shop that has experience doing this kind of work and they are known for doing good work... please post their contact info.  Thanks!
But, most shop are afraid to alter wheels claiming it is a legal liability to do so.
So, I need to find a shop  that does wheel work and is experienced in doing this
Most machine shops will do it. That's how a lot of people widen wheels is through a machine shop
  • Thanks 1
    erickn520
    erickn520
  • Who's Online   3 Members, 0 Anonymous, 660 Guests (See full list)
