Still posting here since the admins have not created a section for the new 2022 silverado.
stock size is 275/60/20
is anyone running 285/60/20 tires or bigger ones with the stock suspension?
if so do they rub?
Edited by Nestor Romero
Added extra info
A stock LT with no lift? 305s are very big tires. I really doubt they would fit without rubbing.
Well I had these 22’s on my 2022 LTD LTZ 2WD completely stock and fit just fine without rubbing https://imgur.com/a/5sAZQwC
I can’t remember their offset so I don’t know if these 20’s would fit. Their offset is 0.
If you could fit 305s on 22" wheels on a 2 wheel drive why wouldn't 275s on 20" wheels fit?
I think you misunderstood my question.
I’m asking about anyone running 285’s not 275’s, which is what I currently have.
My concern it’s because the 305’s
22’s I was able to fit on my old 2022 LTZ were aftermarket with an offset of 0.
These stock wheels on my 2022 refreshed have positive offset.
Running cooper at3  285/60/20 on my stock gmc stock wheels 1500 at4 .  O rubbing, I think chevy has a bigger wheel well?  Also when  going through those radar detector signs was showing the same speed as the truck was up to 40mph.  Have not checked at higher speeds.
Does the AT4 =Trail boss
Which comes with a 2” factory lift?
correct me I’m wrong.
if it is correct what I said then we would not be able to compare them as the LT sits lower without a 2” lift.
Correct - AT4 = Trail Boss = 2" Factory LIft
  • 4 months later...
I ran some ridge grappler 305/55r20 on stock 20s.  2" level in front.  No rubbing.  No spacers.
Curious to hear from anyone that was successful with 285/60/20 on stock Silverado's not Trail Boss not leveled nor lifted in any form.
  • 2 months later...
I have 285/65/20's on my 19 AT4. I pulled in really fast into my driveway at an odd angle once and it rubbed. Other than that, no problems at all.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
    • I had a Gen5DIY DRL relocate harness from a 2022 1500 that I saved. I had Gen5DIY modify the harness for my 2024 Silverado 2500. Plug n Play, worked perfectly.    Here's a video I made for the 2022 1500 truck. The install is more or less the same on a 2500.    The harness relocates the DRL tot he top amber turn signal on my 2500.
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
