I swear it was an option when ordering.... its even in the owners manual but it doesnt seem to be working.
Anyone else having this issue?
You have to turn the wipers on to the lowest intermittent position for rain sensing to work.
I could be wrong. But I believe if you have rain sensing wipers turned on in the settings, it will be active on any of the intermittent positions.
Dirk13 is correct, there is a parameter in the Settings Menu that needs to be turned on for rain sensing to work.
Even you turn on in settings, you still have to be in the first click position of intermittent for the rain sense to work.
In 'Personalization settings':
Rain Sense Wipers
This setting automatically turns on the wipers
when moisture is detected and the wiper switch is in intermittent mode.
Touch Disabled or Enabled.
It is standard on 'refreshed' 2022 and 2023 1500's
SLT,  AT4, AT4X, Denali,  Denali Ultimate
ZR2, LTZ, HC
Unavailable on other trims.
Edited by redwngr
Mine works in any of the intermittent positions.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
