Anybody have any experience plowing with a 1500 denali with magneride? I'm debating putting a plow on my 16 denali 1500 for this winter just to do mine and my parents driveway, nothing commercial and not a ton of work. Have a leveling kit already installed on the truck, which should help sag. Just wondering if anyone has any info, advice or experience running a plow on theirs and what they ran.
Think @aseibel would be a great source to start with, does not have a Denali, but does have a snowplow on a 1500.
All I am going to say is plowing normally will tweak a frame in time and also is terrible on transmissions. The transmissions on these GM trucks of recent years are not to rugged to begin with even without plowing. They are a troublesome area for GM as it is. Especially the 8 speeds and 10 speeds.
Plowing a personal driveway with that truck is no problem. I got a Western HTS which is fairly light. My truck handled it like a champ. I put Timbrens on the front to limit sag. I also threw a couple sandbags in the rear when plowing just to keep the truck level. I always took care to be gentle on the transmission, not hitting the gas until it was fully engaged. I used that setup for about 5 years, never hit snow I couldn't move with it in Wisconsin.
I have no advice regarding the magneride, though.
If you're serious about it, I recommend looking at the plow brands you can get serviced locally. I ultimately chose Western just because the receivers come off, so in summer you don't have any brackets hanging down below the air dam. I had mine trimmed around the brackets, so you would want to see how the front end of your truck will get butchered up to fit the truckside mount on there.
If you have any other questions, hit me up. I researched the heck out of it before I pulled the trigger on mine.
Edited by aseibel
Advise against.  Will eat the shocks fast.
Yeah if you drive around with the plow on for 4 months straight.
It depends on usage. I didn't daily drive my truck because I have a work beater. The new plow mounts are also able to be installed/removed in about 1 minute. I took my plow off if there wasn't snow in the forecast, so I put very few miles on when I wasn't actively using it. If you plan to keep it on all winter because you get snow every other day, and drive the truck to work- this isn't a great idea.
The front axle weight rating on mine is only 3950 lbs. Its not like you can carry a V-blade around. A proper sized half-ton plow only weighs around 400 lbs.
"Yeah if you drive around with the plow on for 4 months straight."
In NY state they sure do that LOL.
OP has a 2016 Denali.  16 Denali is Magneride.  Magneride shocks don't last on a stock truck hardly let alone.  A plow will only shorten their life that much faster.  There's a guy a couple miles from me who has a 16-18 Denali with a 7ft6in Western Midweight that he kept from the HD he replaced.  His valance on that Denali does more plowing than the blade does.  Denali already sits a touch lower than a 4x4 up front, add the plow weight and its bottomed out.
A Denali with magride is a no-no for plowing, plain and simple IMO.  If it had standard shocks, go for it.
Edited by newdude
You should be fine. I have a Snowdogg VMD75 V-Plow on my Silverado 1500 LTZ. I also have a leveling kit to eliminate sag, but do not keep the plow on all the time. At this point I just have the plow on as a back up, but it gets the job done. I believe you will be fine with a straight blade.
Edited by BigBlue2014
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
