I'm thinking of doing a DIY at home flush on my 2018 6.2 with 8l90. Only has 20k on it and shifts great but have heard that the OEM fluid is hydroscopic and slowly absorbs water over time which causes shudder and shifting issues.
I'm betting I need 12 quarts to do the flush at home, possibly more if I want to change transfer case atf as well which holds 3 pints.
Looks like I could do this at home DIY flush in the driveway by:
1. Drop pan, remove old fluid and clean pan, replace filter.
2. Install pan and add 4 quarts of fluid.
3. Remove the cooler block, inserting some poly line in the cooler port on side of transmission towards front of vehicle.
4. Fill transmission with 4 quarts of new fluid.
5. Run engine for 45 - 30 seconds to flush torque converter. Repeat until fluid is clean coming out of poly line.
6. Blow cooler lines out with compressed air
7. Replace cooler lines onto side of transmission.
8. Fill with new fluid and check level.
8L90 flushing proceedure.pdf 8 Speed Fluid Level Check.pdf 8 Speed Fluid Fill Procedure.pdf 8 Speed Fluid Change.pdf
Looks like the Mobil 1 LV Blue label 124715 is $46 for a 6 pack on the jungle website. They have a pic of the old black label but several reviews say it is actually the Blue label 124715
Amazon.com: Mobil 1 Full Synthetic LV Automatic Transmission Fluid HP, 6-Pack of 1 quarts : Automotive
What about using Valvoline Multi-vehicle 773775?
Valvoline MaxLife Multi-Vehicle Full Synthetic Automatic Transmission Fluid (ATF) 1 GA - Walmart.com
Get the right stuff.  Do NOT use the multi-vehicle which when clearly looking at the compatibility chart for it covers Dexron 2, 3 and 6 only, NOT HP.
Only other compatible fluid I can find is Amsoil Signature Fuel Efficient ATF which is the most expensive at $18.69 per qt, $14.39 per qt if you buy the gallon and you are preferred customer. https://www.amsoil.com/p/signature-series-fuel-efficient-synthetic-automatic-transmission-fluid-atl/?code=ATLPK-EA
Looks like I'll prob be going with Mobil 1 LV Blue label 124715 for &7.36 per quart when you buy the 6 pack
Edited by 2018GMC
If there was a dealership that had a service department that’s worth a $hit near me, I’d do the TSB but I’ve been to both the GMC and Chevrolet dealer and they both suck. Several hours for a oil change, they don’t call when it’s done. One of the dealers smashed my Evap canister using it as a jack point. Didn’t find out about that until weeks later when I got a check engine Evap small leak. Of course both denied responsibility.
So here I am doing it myself 🙂
The filter will get changed when I do the work and the pan cleaned since the dealer just hooks up the flush machine and then they’re done.
Edited by 2018GMC
  • 3 months later...
Will trans fluid be covered by powertrain warranty?  Mine is starting to feel like i am driving over rumble strips at times which everyone says is the trans fluid.
Yes, covered under 5/60 powertrain
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
