So my bumper to bumper ends in March. Taking my Denali in next week to look at the rear window, which is leaking again -had it done earlier this year and seemed good until now. I want to get done now just in case they don’t get it this time. The PS power running board button won’t work to extend.
I still love this truck!
Edited by txab
Wrong section
I'm in the same boat, warranty has 4k more miles (though I do have an extended warranty, I am not sure it covers stuff like window leaks). Had my window replaced yesterday and a front shock assembly a couple weeks before. If your window frame is not cracked, you may be better off following the tutorial on here for how to seal the window. Probably last longer.
If this is the 2nd time it's leaked since they "fixed" it. Push to have it replaced. Mine was replaced right after the fix was done and it leaked the day I picked it up. The dealer had a glass replacement shop do the work and it's been good since.
I had a 2015 before this one and never had a problem. I’ll ask about the replacement option. Thanks!
When I had mine done it didn't take any effort to get a window replacement versus the seam sealer fix. The determining variable, I believe, is that I was able to point out a crack in the plastic window frame. Look at yours and see if you can find one!
**After reading more, I think you will be good for a replacement based on it being their second attempt. The TSB does mention first is sealer, second replacement. Disregard my above, my scenario was different than yours.
So I brought it in to my dealer and they called me later and said the frame had cracking everywhere, so they are putting in new one -and they have it in stock. They also confirmed a bad button on the rear of of the automatic running board on the PS side-not in stock, but they are getting one from another dealer, so should have it all done today. I’ll update when done .
Forgot to update that the window is in and we had some real heavy rain and no leaks -thanks GMC for correcting this problem
