Sometimes you want to just move the truck a couple feet, or into another parking spot for example.
And these new trucks wont let you shift out of park without having the seat belt on.
Just testing my luck but Is there anyway to remove/stop this feature?
Does the OM method work?
To turn the Buckle to Drive feature on or off,  select Settings > Vehicle > Buckle to Drive.
  • Thanks 2
See redwngr's answer, right from the owners manual.
Have you considered looking at the owner’s manual?
you can move it a few feet with the buckle to drive off but the chime still comes on if you want to go to the store.....guessing no way to dismiss the chime unless you have a dummy buckle latched in........in the 21 models it was able to be dismissed and chime would go off
It can still be done as redwngr stated:
i tried that.....you can drive the truck but the chime doesnt turn off
So it isn't just to move it a few feet, everyone solved that for you. You want it off all the time so you can run around without a seat belt and not get annoyed with the beeping, in that case just buy that clip that goes in the buckle and problem solved...
Tyler
The clip is free at the dealership.  Just ask for a seatbelt extender at the parts desk.  Or, you know, just wear your damn seatbelt like a responsible person.
On my '21 1500 (doesn't have buckle to drive that keeps it in park, but does have a chime/warning if unbuckled)
it chimes a few times and then gives up.
It will chime again a few minutes later but gives up again.
The seatbelt light will stay on though.
Prior was an '18 2500 that worked the same way.
Buckle to drive is a '23 feature.
It is supposed to give up after 10 or 20 seconds.
It is not supposed to repeat again during the ignition cycle -- so if frequently 'in and out' during during a trip it will not be necessary to repeat the wait (as long as ignition is kept on).
So the '22 2500 doesn't ever stop chiming?
nah i have a 22 RST refresh now.....22 2500 was 2 trucks ago, lol
i turned off buckle to drive but chime still comes on, ill try to give it a lil bit more time to shut off.......on 21 your exactly correct, it just gives up after like the 2nd attempt......ill give this new one a bit more time and see if it shuts off
  • Thanks 1
