I used this on my 2018 Silverado I traded in a year or so ago. You will still need credits and such from BBP
$120 shipped
Oem e85 sensor with female/female quick connect adapter. This adapter makes it so you can unplug your fuel line and put this inline. I did it by my tank. It's shorter and fewer connections over the more common method of buying a bunch of pieces.
$80 shipped (both, won't separate)
$180 shipped for everything.
On the e85 sensor you were able to swap this close enough the wiring you didn't need to extend anything?
Thanks
Dave
Thanks
Dave
Yes, I didn't do any wiring extension. This was at a factory fuel disconnect location.  By using the shorter connector setup I was able to keep it all tucked up pretty good.
    • I'm the original poster of this thread; I'm 85,000 miles now with no transmission issues after they did the fluid change without filter at 45,000.  I plan on a fluid change AND filter in another 5,000 miles and agree with you on staying to witness what happens if possible.  Ideally I would have done the filter at 45,000 too, but my original dealer was incompetent.  I've since moved on and get service done by another more reputable dealer, so I'm hopeful they follow the correct procedure at 90,000.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
