I was having tires rotated and the technician suggested I change lug nuts....it was not a "must do" but they were getting close.  He said sometimes the metal in the lug nuts from GM would expand over time and if I had a flat on the highway it would be extremely difficult for me to get them off.  I have never heard of this so I declined.  Is there any truth to this or could it be a money-generator for the tire shops.  $72 to change them.
he tells the truth.  the lugs have a thin metal shroud over the actual nut.  the nut rusts and distorts the shroud.  if swelled up enough, the lug wrench wont fit and you will strip out the lug nut.  it sucks.  buy a new solid set from the local Autoparts store - and change yourself.  cheaper that way
See the source image
Edited by Bleepster
  • Sad 1
Buy solid lug nuts.
Edited by diyer2
i dont say BS.  has happened to me on multiple cars.  and most recently on my daughters 2011 Sahara.  I replaced all her lugs with solid ones.  thank goodness for Harbor Freight and lug nut extractors
Thank you for this.  I went back and had them replaced. .  He said they'd probably make it to next tire rotation; I went ahead and did it now.  I'm 76; don't need the hassle of that on the road
