Because I want to take the one off my 02 Silverado 4.8 Ls and put it on my 2017 Silverado 1500 LT 5.3 that's y I'm curious
Not really.
The y-pipe will not bolt up at all.
Technically the only thing you could do is chop the cat off that pipe and the exhaust on the 2017 truck, then weld the cat back into place. But it's still possible that the 2002 cat converter does not do enough for the much newer emissions requirements on the 2017 truck. So the check engine light could come back on.
Is it molten or loose? Or do you have fault codes?
The cat should normally last until the car is gone or the converter is stolen 😀
Check engine light blinks and when the tranny downshifts the exhaust vibrates really bad only when dropping into a lower gear it was giving me a code of engine misfire on 3 and 5 so I replaced all ignition coils on negative side all new spark plugs driver and passenger cleaned my throttle body and reset it but I haven't tried changing my 02 sensors just need some different opinions on what it might be causing my check engine to blink that's usually something serious
What are the codes in the truck?  Not a description, but the code number.  So say its P0303.
A cat y pipe would not be compatible from a 2002 to a 2017.  Different emissions requirements, different exhaust layout.
That does not sound like a catalysator issue. I think you should start with a systematic fault analysis instead of just changing parts. Otherwise you probably end up wasting a lot of money.
As @newdude said, what are the fault codes?
I have no choice I had a full scan done and the only thing that came up was a engine misfire on cylinders 3 and 5 and I was told to change the ignition coils and wires so that's what I did but the engine light keeps coming on and blinking from my experience that indicates a bad cat maybe I should perform a smoke test to see if there is a vacume leak somewhere just hoping someone out there might of encountered something similar
A blinking Check Engine Light indicates only misfires. Nothing todo with the catalytic converter.
There are a lot of reasons for misfires. Bad plugs, bad ignition coils, low fuel pressure, bad injectors, broken valves, lifters, compression issues and so on.
I really think you should perform a step by step fault analysis.
I thought this was a place we bounce ideas off of each other y am I being questioned like I don't know what I'm talking about instead of telling me where you think I'm wrong which I'm not try helping me out it has everything to do with the cat for example what steps would you take if you had a deep scan of your vehicle done and you came up with one code so you think you have the problem pinpointed well after repairing all areas that have to do with that code your problem still exists what would you all do that's all I'm here for advice not who's wrong or who's right
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
