I have an oil leak running down over oil filter, cross members, exhaust, bell housing and transfer case drive shaft. Any ideas where it is coming from?
Edited by Frankster
There is no way of knowing without cleaning everything first.
There are many places it could be leaking down from.
Oil pressure sensor
Rear of the valley plate
Rear main seal
Rear cover gasket
Oil pan gasket
Those are just a few places it could be coming from. You will need to degrease and clean everything up and watch for the spot the oil leak is coming from.
1 hour ago, swathdiver said:
Oil cooler fitting or block off plate ought to be checked too.
This is a common oil leak site.....
