Can´t find what type of fluid is used in the transfer case. Have seen on the web different suggestions that say AutoTrak II and Dexron III or higher.  Reading info on both products have found that they are not the same.
If I were able to find the transfer case ID plate, Which I can't, I would know from a list I was able to find on the net that refers to fluid for TC model
Thanks
Thanks
Neither.
Dexron 6.  Been that way since 2007.
  • Thanks 2
Thanks
Did you look in your Owners Manual?  It should be in there.
Nothing there. Says "SEE YOUR DEALER" From experience I know dealers have a way of not following GM OEM specs
Interesting, mine shows Dexron 6 for the Transf. case and does show "see your dealer" for the front axle (4x4).
13 hours ago, BlancoSilverado said:
This is out of a 2019 (newbody) user manual,
For the win!
If all else fails, check the owners manual.  Now for the popcorn... "what's the best Dexron 6 ATF for my vehicle?" 😁
8 minutes ago, Gangly said:
For the win!
Here ya go
:lurk:
  • 3 years later...
I have 2 quarts of this left over from the trans drain and fill. Can I use this for the transfer case?
No, that's Dexron HP.  You need Dexron VI spec.
LV stands for "Low Viscosity"
Dexron VI - 4sp, 6sp and Transfer Case
Dexron LV - 8-sp (Low Viscosity)
Dexron ULV - 10-sp (Ultra Low Viscosity)
Edited by Z45
Thanks
Here is a good capacities guide and reference of what fluids you can use.
https://www.amsoil.com/c/products/1/?zo=521390
    250.6k
    liddlera
    liddlera
  • Who's Online   5 Members, 0 Anonymous, 616 Guests (See full list)
