My key stopped working in the ignition. it happened with out any prior issues of any kind . I have had many Chev and other vehicles over the years and usually there is some kind of prior indication of ignition problems from sticky keys to the tumblers in the barrel becoming problematic. This how ever just happened with no prior indication . When the key is inserted the odometer will light up as it usually does. The steering is not  in the lock position so that is not an issue, the key itself has never had extra keys on it so  extra hanging weight  is not an issue , the key ( see photo below ) is in good condition by all appearances with no indicated wear or bending.  When the key is inserted slowly I can hear tumblers clicking ( not sure if all of them are ) . The only thing that has changed was a sever cold snap for two days which is now over, but it was during that time that the ignition stopped working and still does not work.
I grew up with cars and trucks , race cars etc....and worked in the automotive for a number of years as a certified tech and the last 26 years as a certified Industrial mechanic (Millwright) I have checked everything that I could think of . I bought the truck brand new off the showroom floor and have been the only driver it currently has 163,000 KM (101,283 miles) on it.
Any suggestions or ideas would be greatly appreciated.
Billy
Billy
Does your 2nd key (assuming you've never used it) do the same thing?
No it does the same thing, both will unlock the door no problem and both are in good condition with no signs of wear.
I am going to check the small mechanical cable that connects to the lower part of the ignition assembly on the right hand side of the steering column and connects into the cylinder of the ignition  I am having trouble finding detailed information on this mechanical cable , or any other mechanical components that would prevent the key from turning or even a mechanical diagram on the web.
When you say the steering wheel is NOT in the lock position, I'm not quite understanding. Mine gets  locked when ignition is turned back in off position otherwise the key cannot be removed.
Just to add, I have occasionally had the issue where ignition would not turn. If I grabbed steering wheel and yanked it hard either right or left while tying to turn the key, I could get the ignition key to turn properly. Not sure why but only happened a few times. I think it was from front wheels binding up against something.
FYI
This is the only info I can find its a photo of a replacement ignition unit from a 2017 1500 Silverado. The ignition  cylinder lock actuator cable has been know to cause problems  GM has a recall on some 2014 and 2015  Silverado models  due to this problem. Tomorrow I will check this on my truck if the cable is sticky or  stuck  before i jump the gun and spend a chunk of money on either  a new key cut or and entire ignition , as this issue only happened after a sever cold snap with no prior issues at all.
The steering is not in the locked position
Have you tried putting the gear shift in natural?
It is possible you got some pocket lint in the lock cylinder, See if you can look inside or try blowing it out with compressed air
Mine does not get locked when i turn the key off unless i try turning the wheel on purpose then it will go into the lock position at that point i have to turn the steering wheel a bit to get it to unlock so my ignition works , right now my steering is not in the locked position
Thanks Richard that is one of the things I will check in the morning, when I removed the plastic housing on the steering column there was quite  bit of crud and dirt on the entire ignition housing assembly I  am thinking this is hopefully a part of the problem, there was never a problem or indication of a problem even ever so slight until the extreme cold weather we had that's when this happened .it was -45 Celsius ( -49 Fahrenheit) for 2 days, I just figured the metal parts had frost on them and it would be ok when it warmed up  - not so.
  • 4 months later...
On 6/13/2023 at 9:11 AM, Evan Martin said:
Did you ever find a solution to this? My 2018 3500 just started doing the same thing.
I took the assembly out of thetruck put it in a vice with the key in it and put a pair of channel locks on the round part where the key goes in and forced it , amazingly it turned , I worked it back a force a few times and it has worked fine ever since
  • 6 months later...
Just had this exact thing happen to my 2017 gmc sierra 1500, severe cold snap here overnight -30 before wind, went to remote start it and nothing. Tried the key, wouldn't turn in the ignition no matter what i did/tried. Going to get a mobile mechanic here today to see what he can do.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
