I have  a 2019 Sierra, in March 2020 I got the break recall done.  I turned on my truck earlier in the week and it said Brake Failure, Top Speed of 43 MPH, towed it to the dealer, and they reprogramed something.  I drove it home and started it an hour later and it said it again, but Brake Failure, Top Speed of 63 MPH.  Now they are replacing the master cylinder.  I know this is a problem with these trucks, is the master cylinder going to fix the problem? From what I can find GM knows about it, but doesn't know how to fix it.
Thanks,
Seen the message before.  Been able to drive faster than the message after checking the brake feel and knowing they stop the truck.  Had no issues, and never went to the dealer for repair.  I think there's an occasional electrical gremlin running through the truck.  When it happens it's usually at startup.  Electrical gremlins suck.
Thanks,
This is certainly not what we like to hear, Justinrb70.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 GMC Sierra. To do so, please send an email to [email protected] with ATTN: Justinrb70/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
www.gm.com
I sent an email with all of the problems with this truck.  After putting three transmissions in my 2014 Silverado, the first at 100K miles, the second under warranty, and the third 50K later not under warranty, I'm getting a little tired of new GM trucks.
I got that message twice in my truck.  The first time, I was told that they could not do anything because the check engine light went away before I got to the dealership.
The second time was at 5000 miles.  They replaced the master cylinder and the brake control module.  I am now at 8700 miles and have not had that problem come back yet.
I just had what the stealership is telling me was a failure of the Master Cylinder on my 2019 Silverado with only 16K miles on it. Almost killed my wife and kids.
Now they want to charge me $2500 for the pleasure of driving my paid off truck again. Never again will Chevy get my money, taking it to a local mechanic for less than half for aftermarket parts that can’t be any worse than OEM.
Did this issue return?
Aftermarket doesn't make a brake master cylinder for these trucks so good luck with that.  The master cylinder with module is a $1644 part.  Used would be your only alternative and that can be a gamble.
Even if you took it to an independent, they will have to send it to the dealer for programming anyway so you will spend close to the same amount of $$$ all said and done.
Also.  The whole "almost k!lled" thing, you still have brakes you know.  The braking system still has to provide braking if the assist fails, you will just have increased pedal effort.
Edited by newdude
I would have made the same statement if my wife was driving a low mileage vehicle and the brake assist failed. She wouldn’t be able to panic stop the vehicle. So she and any one with her would be in jeopardy. I gravitated to older vehicles because you can no longer trust a low mileage vehicle anymore. And you can buy aftermarket. So yeah he has a right to be upset.
Im having the same issue with my 2019 Sierra 1500 AT4. All of the same warnings. It will go from no more than 62mph to 43 mph, then at some point, no brakes at all...to the floor! So "newdude", I understand what cmb1982 is saying. This has happened to me 5 times. I've had it towed 4. It all started with a simple brake pad and caliper change and now I am quite literally taking my life in my hands driving my truck because, "it seems to be fine" and isn't currently throwing any codes. I drive it for a day, maybe 4 or 5 and they fail again. 6 weeks I've been dealing with this and nobody can figure it out.
The vehicle was not placed in service mode when the pads and caliper were replaced. I believe the caliper is bad or acuator was damaged, but nobody wants to listen to me. Any ideas would be greatly appreciated. I don't want GM to just start throwing parts at it until something works. I want to know what the problem is and deal with it.
Looks like the grounding strap strikes again.
TSB(2019 & up):
#23-NA-201: Loss of Steering Assist and/or Loss of Brake Assist Malfunction Indicator Lamp (MIL) Illuminated - DTCs P25A2, U0422, C1595, U0420, C116C, B3205, B127B, and/or B1325 Set - (Dec 14, 2023)
Some customers may comment on one or more of the following conditions:
  • Loss of steering assist
  • Loss of power brakes assist
  • MIL illuminated
Some technicians may find one or more of the following DTCs set:
  • B127B
  • B1325
  • B3205
  • C116C
  • C1595
  • P25A2
  • U0420
  • U0422
This condition may be caused by High resistance in the G132 and G133 grounds, located behind the RH wheelhouse liner.
The warnings that I am getting are:
Service ESC, Steering Assist Reduced, Service Trailer Brake System, Brake System Failure, Speed reduced to 43mph
These warnings come randomly, when I'm driving, and twice it's happened after the truck has sat either all day or overnight. All I did was turn it on.
I also hear a slight 'tick' when I press, let up or hold the brake pedal.
One very strange thing that happened one of the times I lost the brakes completely...the dash instructed me to lower the driver side window, raise the driver side window, lower the passenger side window, raise the passenger side window. As soon as I completed those commands, the brakes went to the floor.
So, I have been reading about the "Brake System Failure" w/ the Sierra shortly after changing the brakes. But with my wife's truck she was just driving down the road attempting to slow down to make a turn and the "Brake System Failure" message appeared and according to her she lost all braking capabilities. Does anyone have any insight?
What did the dealer say?
If she 'lost all braking capabilities' I hope she is alright and got the truck towed from that location.
The brake messages are either a fault with the brakes, or a fault with the sensing system.
If the truck lost all brakes, the sensing system was doing it's thing.
Edited by redwngr
www.gm.com
Hello,
I too am having this problem on my 2023 sierra 1500 SLT. The dealer says they can’t find anything but it has happened twice already. I’ve opened a claim and they tell me that the dealer said they didn’t find any codes but I personally was able to pull the codes, so I know they exist. In addition to this the service woman that received my truck that day said some codes were showing. This is a huge safety concern and the loss of braking is no laughing matter. Their attitude towards the situation is unacceptable in my opinion. Customer service at GM said there is nobody to escalate this situation to. Please give me some direction on where to go.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 960 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
