Recently my battery has died at random times.  Sometimes it cranks slow and starts, other times its dead.  It started and i drove about 35 minutes to the store, came out less than 10 minutes it was dead.  Jumped it and drove home it sat over night and started fine.  It does it randomly and nothing is staying on, and i dont have any accessories hooked up to drain in.  Could this be the battery? Or the alternator?  Its been like this for over a month
Yes, it could be the battery or the alternator.
Take it an AutoZone, or O'Reilly, or any auto parts store and have them check the battery.
First time would be the last time.
Have your charging system tested under a load and if the amperage is up to spec. then replace the battery. AC Delco and Die Hard are good brands to consider.
#PIT5985A: Diagnostic Tip: No Start/ Ignition Will Not Turn ON/ No Power Due To A CAN bus 2 Issue/Lightning Strike/ Failed Over The Air Update - (Mar 6, 2023)
Subject:  Diagnostic Tip: No Start/ Ignition Will Not Turn ON/ No Power Due To A CAN bus 2 Issue/Lightning Strike/ Failed Over The Air Update
Involved Region or Country
North America
Condition
Some technicians may experience one or more of the following concerns:
  1. No Start
  2. Vehicle will not crank
  3. Vehicle will not enter into Key On, Engine Off mode (Service Mode)
  4. Vehicle's Instrument Panel Cluster will not Illuminate
  5. Vehicle will not shut Off.
In addition to the above concerns, when using GDS2 to connect to the vehicle, the pop up message seen below will be displayed, prompting to turn the ignition on, but the ignition can not be turned on.  In some cases, after several ignition button presses, the ignition may turn on. Then, the customer or dealer technician may notice that blower motor turns on at a higher speed and then the ignition will not be able to be turn Off.
Cause
This may be caused by either an issue with Can Bus 2, the vehicle received an "Over The Air" (OTA) update that has failed/ or the vehicle's electrical system was damaged by a voltage spike such as a lightning strike or an incorrect jump start procedure.
#23-NA-023: After A Remote Start When The Start Button Is Pressed The Engine May Stall or Will Not Restart - (Feb 28, 2023)
Subject: After A Remote Start When The Start Button Is Pressed The Engine May Stall or Will Not Restart
America, Uzbekistan, Middle East, Russia, Israel, Palestine, Bolivia, Chile, Colombia, Ecuador, Peru, Japan, Kazakhstan, Korea, Thailand
Additional Options (RPOs)
Condition
Some customers may comment that after using the remote vehicle start, either from the fob or app, they experienced any of the following issues:
When they enter the vehicle and press the start button the engine stalls
If they try to restart the engine, it will not crank
If the remote start times out they are unable to restart the engine with the start button
When trying to turn engine off the engine stays running
Unable to turn the ignition off
Service Steering Column Lock Message, if equipped
Dead Battery
Cause
The cause of the condition may be a Body Control Module (BCM) messaging issue.
Correction
Reprogram the BCM following service information instructions to update to the newest software level.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
