I am still under bumper to bumper warranty on my 2020 Z71 RST truck. I went through lots of bugs on a recent trip.  When I was washing them off at a car wash, I saw the clear coat split and come off. There was no rock damage to that area. Is that covered under the warranty? TIA.
One would think?  If you still have warranty. Take it in and get it fixed.  Be stern but be respectful and stand your ground!  Too many people fold when told no or can't do it. If it states bumper to bumper and that's what you have. Ask them to fix it. These trucks gave gotten out of hand in terms in money.  They need to hold up and last for a very long time for the price tags!
Or pull out (or download) the warranty manual and read about the coverage.
Some 'environmental' paint issues are covered 12 mo/12,000mi
Edited by redwngr
If bugs hit then rocks can and is exactly what happened. Paint on all vehicles is much thinner these days, need to do a clear bra on metal painted parts to protect it or it will chip. Probably SOL on paint parts like that on the front end after that much time/miles.
Tyler
I don't believe that will be covered under warranty on a 3 year old vehicle. You will have to read the fine print in the warranty coverage.
21 hours ago, Grumpy Bear said:
3M clear bra is a paint saver. THICK and self repairing.
Thanks! I'll look that up!
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
