Threw charger on my battery today. Batteries less than a year old. The charger said The battery was at 40%. What would be the cause of a low battery? Don't believe it's a drain. GMC Sierra 1500 2013.
Dead cell, bad alternator, parasitic draw from somewhere, battery could have been bad to begin with
These trucks have a smart charging system, the computer will determine what voltage the alternator needs to charge at.
So it can be anywhere from 13 volts up to 15 volts depending on the demand of the computer.
If the truck is sitting for a few days and then you make some short runs the battery never gets a chance to become fully recharged.  The computer system typically keeps the battery at a state of charge in the 70-80 percent range to maximize its life.  A battery being jammed to 100% all the time does not last long.
GMs replacement spec is 64%, a battery that cannot maintain a state of charge at that number (12 hours after charging) is out of spec and ought to be replaced.
If she does sit for periods of time, put a tender on it.  This will also de-sulfate the plates and allow the battery to take a "full" charge again.  I got another year out of a battery by doing this once.
This generation of trucks were not designed to charge AGM batteries.  They won't last as long as they could have.  Just read a caveat in my shop manual, it says an AGM can be damaged if charged to more than 14.5 volts.  Our system can charge at 15.5v if the computer decides to.
Edited by swathdiver
Thank you for that information. I do have an AGM battery. I have a voltmeter on the dash and it never reads more than 14.4. I didn't realize they only maintain a 70 to 80% charge. And it will sit for 3 days and then I'll make a short trip less than 5 mi , then it'll sit a couple more days.
Take her out for a highway run once a week and or put her on a battery tender.
My 2cents. it sits 2-3 days with the power draw for the computers. Then a short trip with running lights, radio, heater on. Not enough time to charge the battery, battery tender is a must.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 721 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
