On 9/29/2023 at 10:33 AM, Rototerrier said:
Your vehicle is charging the batteries while you are towing.
Yes it is, most people don't know that.  When we dry camp overnight at say a Walmart parking lot on our way to another campground, the battery is at a 100% when we stop and typically around 65% when we leave the next morning 10 hours later.  The battery on the camper is keeping our fridge and freezer cold.  It's giving us light, powering up our phones, powering the water pump when we take showers, that one battery is doing it's job big time.  After driving another 3 hours when we stop to stretch, I look at the power meter and we are back to 100% just from the truck and our 165 watt solar panel.  I love it!!!
Just had to cancel a vacation from Iowa to Maine because of this. The truck threw these errors and I suspected the solar causing it. disconnect it (2 hr into trip) in Illinois and all was fine for the another coupe of hrs. then in Indiana started again intermittently. decided better to cancel trip. after awhile it only disengaged when starting the truck.
Edited by Kevin Peele
broken link
On 8/27/2023 at 11:00 PM, UWSkier said:
My truck goes in on Tuesday for service.  Hoping they have the bulletin published by then so I can point the service director to that.  Also need them to figure out why any trailer I plug in says the running lights don't work, and the running lights are always on.  Will update what I hear.
Ah you have the running light problem too? I took it in to Chevy and it's supposed to be a "trailer light module" they need to order a part which they cannot get because of the strike. But I am also having the trailer brake issue as well.
This is true but, it does not charge with a high enough voltage (14.6-.8) volts to fully equalize a LiFePo4 battery(s) which is important for long battery life. You need a LiFePo4 enabled solar charge controller or a proper DC converter to get to the required voltage.
I just have a run of the mill lead acid battery.  When it dies I'll be switching to Lipo.  Our camper is already equipped with a selectable charge controller for the different battery types.
Yes.  Waiting on the two modules.  One is in.  Other is supposed to arrive tomorrow, but I doubt that...
Wait what? waiting on parts since end of Aug? good grief.
I have a 2024.  It was diagnosed as needing a new trailer light control module in addition to the updated brake control module at the dealership two weeks ago, which is when they ordered the modules.  Computer still saying the light module will arrive today.  It's scheduled to go in for service tomorrow.
Edited by UWSkier
 I am so glad I found this thread. I am on a sunny road trip with my 2024 3500  Duramax which is  is disconnecting it's trailer controller and chimming constantly as I tow my TT with 300 watts solar  & 1.000 miles to go!!!
I will try disconnecting solar and or  removing #84 fuse and try to keep my sanity! I will give an update to see if this cures the issue.
Interestingly the last trip was cloudy and I did not have this issue.
Turning off the solar will help but you still might see it briefly from time to time.  At least that was my experience before I bought a cheap diode and wired it in.
Brought the truck in for its first oil change (complementary) and told the dealer about the brake controller issue when towing our travel trailer. They've ordered a new updated brake controller. No commitment to when it will arrive sue to the strike.
New brake controller arrived today. Bringing the truck in next week for install and re-programming.
Shocked that it took only 5 days to get here.
both modules swapped out and both problems fixed!
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
