Same here.  New module arrives at dealer Monday and should get it installed next week sometime.
Ok, just hitched up and towed for the first time…and even without solar I had the disconnects. Since I was just taking it in for a maintenance issue, I just turned the battery off and it solved the problem. But…Thursday we leave for a trip and since I have a 12v fridge I don’t really want to turn the battery off. Can’t get the fix done before then…what’s my best course of action? Any recommendations?
How far of a trip are you taking?   If you plug the rv in the day before and let the fridge and its contents get good and cold well before your trip, it will essentially act as a cooler when not powered on.   Or do you have a propane option?      I have another older travel trailer, the fridge only works on shore power.  I’ve camped with it several times by letting it all get cold for a few days before we left.  The day of the trip it will stay cold well over 9 hrs of driving until I get to the campground.
How hard is it to get to the wiring on your trailer?  I wired in a diode on my black 12v power feed line where it comes into the RV so that power can only flow from the truck TO the RV but not in reverse.  After doing that, I read 0v on the 12v pin of the trailer when it's sitting disconnected from the truck.  It shouldn't take more than 20 mins if you have decent access to the wiring.
Don’t have the propane option, but you make a good point - it’s a short trip, about 2hrs. So I think if I have everything good and cold I’ll be fine with the battery disconnect off. I can always throw a few reusable ice packs in if I’m really worried about it. I’m so used to the fridge running on the drive I missed the obvious that it’ll stay cold that long.
It’s our last trip this year, so I’ll have the dealer take care of the fix (hopefully) we’ll before I have to tow again.
Keep in mind that the battery quick disconnect only disconnects the 12v power going to the coach from the battery, but not from the truck to the battery or from the battery to the truck.  That was the first thing I tried when troubleshooting after reading the bulletin.  You’ll need to disconnect the negative lead from the battery to actually prevent the battery from back feeding. Or do as the others have suggested and wire in a diode.  Not sure what timeline you have but I couldn’t get one local and had to order one on Amazon.  If you can’t get one and wire it in before your trip, turning the battery disconnect will only kill power to your refrigerator but still give you the error message and turn off your brakes.
I was hoping someone would clear that up.  You are absolutely correct, the only way to turn the 12v fridge off is to shut it off with the knob inside the fridge or unhook the battery.  The battery disconnect does not turn your fridge off.
The battery quick disconnect will cut power to the 12v fridge and everything else inside the coach that runs on 12 volt ie. the interior lights, vent fans, water pump etc.    The point I was making is that the brake issue is due to the trailer battery back feeding into the truck.  The battery will still back feed into the truck even with the quick disconnect turned on because it only cuts the circuit to the internal 12v system of the rv. The running lights, brakes, and battery will still be powered and connected to the truck which wil cause the module to shutdown and give you brake issues.
If I’m understanding the issue that causes the problem correctly, can it be solved simply by letting the battery run down some before it’s time to hitch up and go? The fridge will put some drain on the battery as well on its own, and if it’s unplugged from shore power for, say, and hour or two, before travel…it shouldn’t be getting enough charge from the truck to be fully charged while on the drive? I thought I was understanding that the issue only occurred when the battery became fully charged and would back feed to the truck, but I’ll be the first to admit my battery/electrical knowledge is not my area of expertise. Oddly, the disconnect seemed to work today, but it was only about a 20 minute drive so that could’ve been a fluke.
edit: I also do NOT have solar, so the only charge the battery would get while driving is from the truck.
Edited by Salzette
I got the updated part installed last Thursday and removed the previously installed diode and did a 200+ mile drive with ZERO issues.  Looks like the updated brake controller finally fixed the issue.
For the sake of everyone reading, there were 2 solid solutions that worked without issue, and 1 potential solution.
Solution 1:  Installed Diode on the 12v charge wire (Black) from the Truck to trailer.  This prevented all back feeding and worked for long drives without issue.
Solution 2:  GM installed new Brake Controller.  Took them less then 1 hour for the install.  They did have to order the part which took a couple days.  Was fully covered by warranty.
Ideal Alternative Solution until you get GM installed updated Brake Controller:  I purchased the Curt Echo Mobile Bluetooth brake controller.  This is put inline with the trailer plug and bypasses the trucks brake controller.  You can control sensitivity and gain using a mobile app, and can even have a manual brake button on the phone.  I drove 2k+ miles using this setup.  I was very annoyed that I needed to use this adapter on a brand new 2024 3500 GMC, and lost the ability to control gain and manual braking with the in-truck controls, but it was better to have reliable brakes when I was going through a lot of mountains.
Potential Solution:  I attempted a drive with all 12v accessories turned on in the trailer while driving.  Fans, Lights, Fridge, etc.  This was an attempt to keep the charge on the batteries low enough that the back feeding would not occur.  It worked for about an hour before the 550watts of solar was charging faster then the usage.  This may be a viable solution for trailers with little or no solar.
Apparently it's different with different manufacturers.  On our Grand Design the battery disconnect does not turn power off to the fridge.
This is true of most units with an inverter that powers a residential fridge. I can disable both giggy boxes but still have to turn off the inverter if I want to shut down the fridge. It's a wonder trailer wiring works at all LOL.
  • Thanks 1
Took my truck to the dealership on Wednesday. The service writer instantly acknowledged that they were tracking this issue. They ordered the replacement module, but don’t have any estimate on when they will get it. Told me that they hadn’t received any parts orders this week due to the strike.
I installed a switch to shut off my solar panels and that took care of my brake controller issue.  Unfortunately now my solar panel won’t charge my batteries when I’m towing.
    Afennell19
    Afennell19
  • Who's Online   2 Members, 0 Anonymous, 826 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
