I just recently traded in an 18 6.2 Silverado 8spd 3.23 gears for a 23 Sierra 6.2 10 spd 3.42 gears with Max Trailering.  I test drove it very little and was generally just getting rid of the 8 spd before the warranty ran out. A few weeks after, our boat (pulled many times with the '18) was ready for pick up and on the tow home I needed to pass a few cars.. In which it just doesn't have the get up as the old '18 when you swing out for a pass... That 18 used to set you back in the seat this 23 just feels like a 5.3, I was really expecting the '23 to have much better mid range with the lower gears and 10 speed... Anyone else feel like they dont have the power they used to? If I had known it would be this lack luster I might have considered the diesel a little more.
EDIT If someone told me this was a second slower in the quarter mile vs the 18 i would believe them
Edited by BB68
I didn't tow anything with either truck, but went from a 2020 5.3 8-speed to a 2021 6.2 10-speed and the 6.2 was noticeably quicker and had more torque.
I’m spitballing here it goes. A few years ago I was reading car and drivers test with the 6.2 and the new 10 speed. The 0-60 actually slowed a bit. The speculated was that the tq management was slowing it down with more shifts more tq management. Perhaps depending on your speed and passing you drop multiple gears. While shifting back up through the gears at full throttle or near it. TQ management was de throttling to ease stress on the transmission. Love those nannies. I always wonder with the TQ range if all those gears was overkill.
I fully agree on more shifts = slower ET.
While towing/passing it down shifted once and hung out in that gear the entire pass. I dont know what gear that was as I am still getting used to this new display.
I will also agree the torque management system intervenes quite often. With the 18 if you took off from a stop sign at full throttle each time it shifted you could feel the throttle pulling back and also hear the tire stop squealing until it was fully in the next gear. I have not performed any stop sign acceleration test yet with the '23, will after a couple oil changes.
I just want to know where you found one with max two package! I'm looking for an RST with the 6.2 and max tow... within a few hundred miles of me.. no dice
I went from a 2010 Yukon Denali w/Max Trailering (6.2L, 6 speed) to a 2023 Silverado 1500 crew cab short bed w/Max trailering (6.2L, 10 speed).  I tow a 7100 pound travel trailer.  The new truck has 6000 miles, 1500 of that was towing.
I feel the new 6.2 is plenty strong.  With the Yukon, I felt the need to use WOT somewhat often when towing.  With the Silverado, I think I've used it maybe once.  It just doesn't seem necessary.   I think the additional gear ratios in the 10 speed help that perception.
Another difference I have noticed is the use of the top gear.  Then Yukon would almost never drop into sixth gear when we are towing.  It would usually be in fifth on flat ground.  Both vehicles have 3.42 gears, and eighth in the 10-speed is the same ratio as fifth in the 6-speed, so I expected to mostly be in eighth.  But it actually spends a fair amount of time in tenth.
The biggest challenge I've given the new truck was Raton pass (6700 feet to 7800 feet, so pretty mild) and it pulled like a champ with no drama.  I'll hit the Eisenhower Tunnel in June.
But the shifts put you right back in the power band on a 10A vs 8A?
The T1 is heavier and has a bigger overall footprint so i would think it would be right around the K2 6.2s .
I also think the stock tires are also one diameter bigger on all models.
I have had 2 K2 6.2s and now my 2019 6.2 , they both feel pretty much the same to me.  I mean its the same engine output so if there is a difference its very little .
I still cant believe we are going on 10 years with the same engine outputs.
3 hours ago, f8l vnm said:
But the shifts put you right back in the power band on a 10A vs 8A? That only matters when you have a very short torque curve... these 6.2s are like a 454/8.1 as far as torque curve.
The T1 is heavier and has a bigger overall footprint so i would think it would be right around the K2 6.2s . Its probably close enough that I shouldnt be able to feel it.
I also think the stock tires are also one diameter bigger on all models. Same size tires on mine
I have had 2 K2 6.2s and now my 2019 6.2 , they both feel pretty much the same to me.  I mean its the same engine output so if there is a difference its very little .  This T1 6.2 is neutered compared to my 18 K2... I have hauled that boat all over with the K2 and know the feel. I believe torque management maybe over stepping its bounds here
see responses
2010 6.2 to LT6.2 is a big jump and I believe it does make more midrange power.
This '23 is adequate, just does have the mid range punch the '18 had. Right now I'm a little disappointed. Time will tell next month Ill have another 8 hour haul down to TRL, that will give some seat time in the mini mountains
I missed out on a couple at Laura (like hours)... But I had a backup somewhat local and I found that they quit making them for a while so I took the plunge. Not as good good of deal but hopefully I'll have a place to fit me in if I have any repair needs
I went with GMC this time due to my distaste of current Chevy design.
see responses
"That only matters when you have a very short torque curve... these 6.2s are like a 454/8.1 as far as torque curve. "
Are we looking at the same torque curve? The 8.1 has over 90% or its torque available around 1k rpm and peaks around 3k, it doesn't like to rev much and is similar to the old V8's making a ton more torque (which peaked way low) than HP and wasn't rev happy. The 8.1 makes peak HP just over 4k rpm, nearly 1500rpm lower than the 6.2. The 6.2 likes to rev, makes only 70% of its peak torque a little over 1k rpm and peaks the torque out over 4k rpm while HP goes all the way to 5600. The 6.2 in the trucks is very similar to the corvette/camaro motor (at the time), not exactly a stump pulling torque monster that 496 or 454 were known for. Gotta rev it to make its power.
This is why these smaller turbo motors are great, you get most all the goods of the torque way down low as can still make great power up top. Best of both worlds.
Tyler
Tyler
Whoa buddy..... this thread is about a current '23 6.2 to my previous '18 6.2. Have you had any time behind the wheel of both?
I agree with you. I went from a 2017 6.2 to a 2020 6.2 and it feels like something is bound in the drivetrain, not allowing it to spin up as freely.
I agree, drove plenty of new 6.2 yukons & trucks and my 2020 5.3 feels almost the same. Older 14-18 6.2 felt like rawer power. The problem I think is the 6.2 is heavier by a good bit over the 5.3 and doesn't make a enough power to offset the weight difference or enough that you can noticeable feel
Edited by luke1333
I doubt there is much weight difference.
    btm
    btm
  • Who's Online   4 Members, 1 Anonymous, 1,556 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
