I have a ‘21 Sierra HD that I had opened up the forward stake pockets for mounting a rack. Now I’m not using the rack and would like to cover up the pockets.
Trying to search for the covers is a challenge because the market is flooded with the covers for the rear odd-shaped pockets that are uncovered from the factory. So it’s not an issue covering the rear pockets, but I can’t seem to find the right covers for the forward pockets.
I measured the hole and it appears to be around 1.5” x 2.5”. From what I can tell, the pockets for the pre-2019 models are slightly wider, the covers are 1.75” wide, so I’m not sure they will fit.
Anyone have any luck finding covers for the front pockets?
There likely won't be any because they are molded part of that entire upper plastic rail protector, and are cut out if certain accessories are to be installed that need to use the front stake.
Right, but the pockets _are_ meant to be opened, so it makes sense that you may want to cover them up again. I have to assume the right size cover exists out there somewhere...
But because it was a molded cap, there isn't a replacement once its opened...
Aftermarket makes rear ones for the big hand pockets at the rear, but nothing for the front.
  • 4 weeks later...
What did you use to open up the front covers?  I'm getting a removable rack for my truck and will need access to the front stake pockets.  Sucks there is no cover to put back in place when rack is removed, guess I'll have to attempt to make some sort of covers for them.
You might try someone with a 3d printer. I have the rear pocket covers but never saw anything for the front.
yep, that would definitely be the way to go if unable to make some sort of caps.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
