6 minutes ago, MrMagloo said:
Clearly you started this thread to highlight to the world that you foolishly made a $68K mistake, and it appears now you want to lash out and punish everyone for your stupidity.  That's OK.  Have fun.
A mistake? LMAO!!
21 hours ago, diyer2 said:
Best answer, because that's the way it is.
This may be a harsh way of putting it , but it’s true. I changed the dash speaker in mine(real easy to do took 20 minutes. I posted the pdf from crutchfield that showed how to remove all speakers and replace them. Speakers cost me 55 at crutchfield but you can get a way better set for around 75. Order the metra 73-4573 for the connectors for the speakers they worked perfectly for me and the sound will be alot better. Door speakers are easy as well. May be some of the guys can speak up about what speakers they used to get rid of the muddled sound.
  • Thanks 1
OK Ted
If your complaining without a solution you're a whiner.
I gave you a solution.
I've found that simply swapping the speakers in my Tahoe and Vette with the premium Bose systems made a pretty nice improvement - and quickly got rid of that boosted mids muddiness. I last used the JL C2's before and they are really nice.  But I don't see a C2 6x9 version that will fit.  So, it seems the C1-690x and C1-650x is the way to go as CF recommends.  Too bad they don't have a C1 to fit the dash.
MShawn, did CF have the Metra 73-4573, or did you source that elsewhere?  I checked Amazon too and they don't carry it either.
I have the bose and also had the harmon kardon system in RAM
always considered myself not to really care too much but I was actually pretty disappointed in both.....I just expected better though realistically it's probably par for the course.....slightly better than the base system which I've also had
Maybe I am stereo snob and never knew it😂
Never spent money really on these things nor am I even huge music nerd......
Just figured it would sound alot better and it really doesnt...
I know they hit price points fir every lil thing so fir sure it's the cheapest they could get away with.....
Many change just speakers out at some point but that's it....
It's probably not even a Bose or just one piece is
Harmon kardon was slightly better but not by much
I went with JL Audio C1-690x in the front doors.  They made a big difference.  I put JBL Club 622s in the rear doors, and they did not.  The rear door speakers are just muddled.  Dash speakers I went with the Kenwood KFC-X2C, and they made a big difference.  It did reduce the volume of my turn signals though.   I have an amp and loopback harness on the way, that will hopefully make it all sound better.
  • 3 weeks later...
I am also somewhat disappointed in the Bose system in my '23.  It doesn't sound as good as the Bose in my '14 did.  That being said, I didn't buy the truck because of the stereo.  A stereo is important to me, but I'm buying a truck with a stereo, not a stereo that happens to have an attached truck.  I may get around to upgrading speakers at some point, but as of now, it's good enough - just not awesome.
  • 4 weeks later...
Sorry I just saw this…. I order the metra speaker harnesses from Amazon. Walmart Carrie’s them Lao and can be ordered.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,477 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
