Yeah, you can see the right side hinge isn’t 90 degrees and your tailgate top on the right sits about a 1/4 inch lower than the bed rail. It definitely got hit in my opinion.
2 minutes ago, Sqrls said:
You hinge is bent. Someone probably backed into something with tailgate down. Probably thought it barely touched and didn’t tell anyone. That’s exactly how mine looked on my last truck when someone hit that side of my tailgate while it was down. It’s not just the hinge on the outside, there’s a PITA to get to spring on the inside of that fender as well. If it’s not 100% perfect, you will wear out the slow close bushing super quick over and over. Probably also need a new tailgate.
I was never able to get it perfect on my previous truck.
After an hour drive to the dealer this morning to drop it off and pick up the loaner car and a other hour drive back, they took the truck to their sister dealership where the body shop is and had it fixed in a few hours.  Drove another hour there to grab and it another hour back…so a total waste of a day. Anyhow, they didn’t say what it was…but it’s as flush as flush can be and it all worked out.
Good to hear, i was going to guess a rather non skinny person used the tailgate step and bent it. Glad that's not the case...
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
