Just installed a banks idash guage in my 24 2500 gasser, i have found parameters for rpm, voltage, water temp.  But i can not find oil pressure, oil temp, and current gear.  Which is the reason i wanted the guage. I have verified the correct software version, 1.24.0.  I have not yet contacted banks, just wondering if anyone here has dealt with this.
Edited by Agargano98
  • Agargano98 changed the title to Banks idash
Can’t help with the idash but if you return that and buy a scangauge 3 you will find lots of threads now about it. All those things you want are available with the sg3
13 hours ago, Agargano98 said:
Just installed a banks idash gauge in my 24 2500 gasser, i have found parameters for rpm, voltage, water temp.  But i can not find oil pressure, oil temp, and current gear.  Which is the reason i wanted the gauge. I have verified the correct software version, 1.24.0.  I have not yet contacted banks, just wondering if anyone here has dealt with this.
There was a documented list of PIDs available that was supplied with my iDash.  Check your packaging and shipping paperwork.  I also remember looking over the instructions and list on-line before I bought the iDash.   My iDash has been flawless and has many more display options and parameters than the scan gauge 3 I used in my previous 2018 GMC Canyon with 2.8L "mighty mouse motor" Duramax.
I talked to Banks tech support today.  They are currently working on an update to expand the parameters for the 2024 hds.  And i should be good once that new update goes through.
The newest version is 124.7 are you sure you looked into all the category lists?  Those simple parameters have to be there. I have an Idash on my GMC 2500 HD 6.6. they are really nice to have.
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,063 Guests (See full list)
