Greetings fellow members. I own a 2020 Silverado 1500 LTZ crew cab Z-71 with the stock Z-71 suspension. It’s going on 4 years old soon. The rancho shocks are getting tired. What would the forum members recommend for a replacement? I prefer to keep the stock ride height. It’s my daily driver. I went to some suspension website and I saw Bilstein and Fox have 4 shock/strut kits starting around $1000. Is that what I should expect to pay for a set of good quality shocks? If I left any details out please let me know.
www.shocksurplus.com
They have good comparisons between Fox 2.0 IFP's and the Bilstein 5100's for how you want it to feel. Both are able to retain stock heights based on where you put the circlip and both are valved properly. You will be happy with both over stock. Fox's a bit softer, but controlled. 5100's will be more firm/sporty, better for towing.
Edited by Vincej138
I just put Bilstein 5100's on all four corners of my 2022 LTD. I set the front at 1.5" and lifted the rear 1" using an OEM block. Gave the truck a better stance overall IMHO.
I've run Bilstein 5100's for years on various different trucks. I enjoy the ride they provide, and the flexibility of the ride height adjustable struts.
You can use 5100's at stock height. Or the Bilstein 4600 is a non-adjustable cousin that would be stock ride height as well.
I used shocksurplus.com to purchase mine this most recent set. But https://www.suspensionlifts.com/?gad_source=1 is honestly better pricing and more info.
Good luck.
I went from the stock Ranchos (junk imo) to some new take-off DSSV's. Night and day difference.
Not sure if you have a 2" factory lift? My AT-4 does and the Multi-Matics bolted right up.
I have also got bilstein 5100s on all 4 corners they are great way better handling all around a great shock and strut. I just got the front done in January but I had the rear for about a year and they are awesome. I set the front at max height and got a 2 inch block for the rear. But you can indeed run it at stock height if that's what you like.  I have a 2020 silverado ltz 6.2. The front ones were really well used with over a 100k kms on them. I got them on gbp performance because it's Canadian website.
For sure I was gonna go with the 6112s but then I saw your YouTube video and that help me decide the 5100s I might upgrade to fox or kings in the future when I won't be using my truck for much towing. I'm also thinking about getting cognito upper control arms too.
  • 4 weeks later...
Going with Rancho RS7MT (linear piston) They also have a 15% off right now. Similar to Blistein 5100 (digressive piston) but a little softer. Either mono tube will be better than the stock AT4 Rancho twin tube. But all depends on what your usage is…
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
