2023 2500HD
I've searched the manual, it does not list a mileage / time for chassis lube. So I assume at every oil change, 7500/12 mos. or whenever oil life monitor says.
Anyone know for sure?
Things like that are kinda up to the owner. Just do it when you feel it's required. With these new trucks you don't really need to do it very often unless you are just pounding miles, going offroad, abusing the truck. A pavement princess isn't going to wear out joints going from parking lot to parking lot.
16 hours ago, wsrutherford said:
2023 2500HD
I’ve heard every oil change like you mentioned. Easy to remember too that way. Might only need a pump or two each. I’ll be checking mine when I do my next oil change.
Would love to know how many zerk fittings we have down there to grease. Or better yet, photos of them all. I've noticed some clunking starting on my '22 and once it stops raining and I have an afternoon to myself, I'm headed down there with my grease gun. I had to do this on my 4runner a LOT.
4 ball joints, 2 tie rod ends, 2 idler arm, 1 pitman arm, i think is all, that's all I've found so far.
Edited by wsrutherford
BTW it took a lot of grease, I had my hand on the rubber boot, as soon as I felt it move, I gave 1 more pump, never did blow any grease out. Truck only has 2200 miles, I had on it my lift just looking around.
Those are them.  9 total.
7 hours ago, jeetS said:
No ujoints?
Not until you replace them. Most replacements are greaseable.
On 3/24/2024 at 2:21 AM, jeetS said:
No ujoints?
No.  Stock are sealed, usually last quite some time now too.  We rarely replace u-joints nowadays.
  • 6 months later...
I have a 2019 Chevy Silverado V8 the 5.3 l engine with an 8 speed transmission. I do not see any grease fittings in the front end . So I guess they don't need to be greased like in the old days.
1500s are sealed, and this is the HD section.  HD are still greaseable.
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
