Hi, about to change front and rear differential fluid. I have AAM (SU4) for the front, which takes ACDelco 10-4091 (GM 19300457) 75W-85 High Efficiency Synthetic Hypoid Gear Oil. My rear differential is GM (SU8 with G80 positraction limited slip & GU6 3.42 ratio) which takes ACDelco 10-4122 (GM 19368514) 75W-85 DEXRON Low Viscosity Gear Oil. I see many recommend swapping them with Amsoil severe gear 75W-90 100% synthetic gear lube. Can you confirm this is right fluid for the stock fluids? Looks like our trucks have 2 kinds of front & rear differentials each with their own specific fluid but can this Amsoil severe gear replace any of stock fluid? What are the benefits? Can I change fluid every 100,000 miles if I use Amsoil? I am not hauling or towing anything… thank you.
Edited by Interleukin6
You can go on the amsoil website too and they may list the fluid you can use when you search by vehicle.
My opinion is that you gain nothing. Sure Amsoil is really good stuff but it's going to work just as well as the factory AC Delco fluid or the Valvoline full synthetic gear oil you can buy at Napa down the street.
If you don't tow anything and don't run it hard, you can still stick with the same 75,000-100,000 fluid changes if you really wanted too.
They are both 75W85. The rest of the description is mumbo jumbo. Although I am a Red Line guy, the AMSOIL Severe Gear 75W90 is as about as good a diff lube as it gets. Why? Viscosity stability. Stays in grade. Nice easy fill packaging too. 😉
It seems that the prices of the original ACDelco fluids are similar to the Amsoil. The benefits I think are only one fluid treats the front & rear both (I need different fluid for the front & rear if use ACDelco) and I don’t need a fluid transfer pump… Can I use a brake cleaner to clean up the differential gears when the covers are opened? Of course I will thoroughly clean the inside of the covers, but I think I need to clean the gears as well before putting in Amsoil to prevent contamination. Is this overkill? Thanks.
How about this... The front differental does have enough space to work... If I just suck up old fluid then put new one without the cover off and removing metal debris on the magnet, is there no point to do this or is it better than nothing?
You know that gasket is reusable, right?
If you plan on keeping this truck for a long time, change it with Amsoil Severe Gear. Well worth the effort and cost.
Any gear lube will work, changing it is important. I like Amsoil.
Edited by diyer2
9 hours ago, Interleukin6 said:
I think the gasket for the rear is reusable but not for the front.
Yes you are correct and depending what truck you have there are different gaskets
-grover67
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
