Ford guy here buying first gmc
Talk me in/out of the 6.6 gasser with 10 speed gmc built allison
Is this allison the same in the 6.6 gasser as the duramax?
Been seeing some horror stories about this tranny time I've been reading online extensively for the past 24 hours
First year in the gasser for this tranny ?
Just came from a ford with tranny issues
I don't know if I should back out of this deal from what I read online, hard shifts, valve body replacement etc etc etc
I really don't know what to do as there are engine/tranny issues with every brand every combo right across the board
Criticism is appreciated and hit me hard with straight up facts
Also, what the heck is up with all the ads on this site I could barley complete my profile
Cheers!
And thanks for having me
- Mike from BC Canada
Well, it’s not an identical Duramax version tranny but mine is working great.
Takes a little doing to check and add fluid but that’s relative to one’s mechanical abilities.
Yes, first year for this hookup that I recall.
Maybe you should consider a Ram instead.
Get an Ad-Blocker. I use 1Block. Works very well on my iPad.
24 GMC here. I absolutely love my 10 speed gasser. I pull a 9k+ camper. It did excellent.  Traded a 22 F250 with the 7.3 Godzilla for it. Didn't like the Ford at all. Had a 2500 Cummins Ram and nothing but problems including transmission failure.  GMC Build quality seems way better than the Ford.
Thanks for the feedback, I'll look into the ad blocker
No problem with the no dipstick for transmission I've dealt with that on ford's before
Not interested in a Dodge but thanks
Edited by Icelink
Thanks for the reply we are getting rid of our 18 F150 with transmission issues ( CDF drum failure) at 75,000 kms
Never buying a half ton ever again no matter what brand/options
I'm keeping my other 2019 F250 6.2 gasser with 6 speed , that combo has served me well
Never drove the godzillla and not interested in diesel
Only have 1600 miles on my 2024 but so far I really like the Allison with the 6.6 gas. Towed some fairly light loads over the weekend for the first time (5k-6k lbs) and it did very well even up some steep hills at highway speeds.  The 10 speed kept the motor rpms where they should be and it shifts quickly but not hard. Time will tell how the reliability will be but so far so good.
Edited by AndrewF
5500 miles on my 24 with 4500 of that towing about 5k with another 1k in the bed.  Nothing but good things to say about this gasser/Trans combo.
  • Thanks 1
  • 3 weeks later...
IceLink sending you a message on here
I’ve always run an ad blocker so never see any ads on any site.
no experience with the 10spd but my 22 6.6 gas with 6spd has been awesome as far as engine and transmission etc. no oil burning and tried and true 6spd has been plenty good for me very smooth.
welcome aboard
  • Thanks 2
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
