Has anyone serviced the transmission in their 24’ gasser? I’m going to be dropping the pan and replacing the filter and fluid in the next couple of weeks. I am under the impression the service should be very similar to that of Duramax trucks. Do you have to drop the exhaust to remove the pan? How much fluid does it take (I ordered 10 qts)? I would appreciate any information from someone who has done this.
I haven't done it yet but I do know you need to drop the exhaust according to the service manual.
When I drop my pan, I will be putting in an after market pan that has a drain plug.
I think you may be able to sneak the pan out without dropping the exhaust. It may need some prying to get it cleared or loosening of the trans mounts and prying up. I consider this an epic fail and a sure sign that Allison didnt have a huge role in this design since they have a history of building transmissions that are service friendly.
Mines good for now but I already have a Superior products drain plug setup thats going on it when I do.
I dont have an exact count on the qts needed but I would buy a few extra just in case.
When refilling the trans I will use the M18 nipple that I bought with the hose and run that up to the normal dipstick area rather than pumping into the side of the case. I believe I posted about the setup before. SInce I know mine is at the correct fill I will just measure the amount I drain and replace that accounting for the inevitable spillage.
Just for grins, I got back from a trip towing my 12,500# fifth wheel in 85 degree temps and my trans never went over 176 degrees with a mic of freeway and stop and go city in the 200 miles.
Maybe its a simple regular cab thing...........  But...........
I just looked under my 2024 regular cab, 6.6 gasser, 3500 4x4. The transmission drain plug is in the front  drivers side of the pan. It wont drain all of it as there is a drop down part. Then the pan can removed very easy without doing anything with the exhaust. Yes, it has to be slid forward of the exhaust then it will come right out, and go back in.
Ill will attempt, to do some fluid sucking to get the rest out of the deeper part of the pan to help with less sloshing.
For the others/normal people with a 4 door. Maybe someone could confirm or post that the exhaust needs to be dropped or not.
(( 64BAwagon )) You posted  right before i hit submit. Did you confirm by looking under for the 4 door people? or i can look when my friend gets back from camping next week and add to the 4 door being like my 2 door or it being a pain. He has a gmc 4 door.
Has anyone looked into if the transmission pan has a reusable gasket or is it like my past 2015 ram diesel with a pan that had, no, drain plug and the pan gasket was not reusable.
I may be mistaken but I believe that plug is used to check the level of fluid in the tranny. The correct level is obtained (while at operating temp) when fluid is reduced to a slow drain. It is not to be confused as an actual drain plug for emptying the pan.
what pan are you looking at?
Pan drop takes just over 14 quarts.  Dexron ULV fluid, p/n 19352619.
That is not "technically" a drain plug.  That is the fluid level check plug for checking the level.
Should be, most all the ones GM uses are these days.
I like to learn things.......
And i thought it was a drain plug.
I mean...yes you "can" drain a fair amount out of there but obviously you won't empty the pan.  There's a stem pipe that it screws into, it will drain fluid to a point at or just below the stem pipe, so the pan itself will still be pretty fluid loaded.
I appreciate everyone’s feedback. I ordered additional DEXRON ULV for the job. I’ll try to come back here with a detailed post of my experience. I’m sure someone else will be looking for this info in the future.
It's a fill level! If the transmission was properly filled, nothing will come out of it.
Level when shut down and level when running are different.
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,351 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
