Hi so last night my truck started doing something it never has before..i was driving for about an hour before i parked it and it drove just fine, no rpm jumps or vibrations or shuddering etc..it shifted perfectly fine as well, but then when I put my truck in park it started randomly making a thumping, not steady just random intervals..can't hear nothing can only feel it in the floor boards, and I repeat it only does it in neutral or park, whenever it's in gear it perfectly fine, I drove it around a bit again after I first caught to it and it still shifted perfectly fine, I have good idea what it sounds and feels like when trans is going or convertor is shot, I also just did a transmission recalibration and got the oil changed one yr ago cuz it was doing the vibration and bit of rough shifting and stuff and that cleared right up..so anyway I read up on forums a bit and can't find anything super similar to what I'm experiencing so hopefully someone has some input? Thanks!
FYI I just tried it again this morning and I cudnt get it to do it, drove forward a bit then I put into reverse to back up again and that triggered it, it made it bit of a slipping feeling then the thumping started faintly then when I put it into park it kept thumping..🤷‍♂️
What year, model, transmission & miles might help. Any mods? R u the original owner? Any maintenance done?
It is a 2016 GMC Sierra 1500 Denali, 8 speed transmission, 217,000 km...no mods other then I recently put a different set of wheels on..but they are the stock 22" Denali wheels with 33" rubber..as well as regular maintenance yes
Edited by jmetz
What about a broken motor mount(s)?
Maybe have someone in driver's seat with foot on brake and in gear. Slightly press the accelerator a few times and see if motor rises up some when doing that?
Edited by mikeyk101
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
